FX1 Resolution in DV Wide record mode
Does anyone know if the FX1 uses the entire resolution of the sensors when shooting in the Dv Wide mode ? Or does it possibly crop off the sides and bottom to fill a 720/480 frame ?
Thank you, Chris... |
I'll guess it's the same as the Z1, which uses the same source image as HDV for DV, it just downscales the image from the sensor and encodes it to DV rather than HDV. i.e if you were to shoot the same angle in DV and HDV, the frame composition would be exactly the same.
Last I checked, it was still widescreen, though you can downconvert both HDV and DV to 4:3. It's pretty cool. But, I'd shoot in HDV widescreen, edit it that way, then down-convert to DV before going to tape--it's much higher quality.
heath |
Kevin is right, HDV, native, is around 3.6 mb per second, like DV. That's how they fit it onto a mini-dv tape.
heath |
