Holding off purchasing nex FS100 - Page 7 at DVinfo.net
Sony NXCAM NEX-FS100 CineAlta
Old November 17th, 2011, 01:12 PM   #91
Re: Holding off purchasing nex FS100
Since we're talking about older lens here, I wanted,to post something I asked,somewhere else, just those what everyone here thinks. This is what I wrote.....
In the process of getting to know my first real "pro" camera (fs100). Been playing will all the settings and such. I've made an observation, and wanted to ask if my conclusions are correct. I'm currently using very inexpensive canon fd lenses, until I have the funds for, nicer higher end lens. When using the peaking function (has 3 settings, high, medium, and low. I'm using set on low), I've noticed situations when I have (or feel I have) good focus (on what it is I'm trying to focus on), but there is no peaking indication at all, and other times when there is. With out having a newer, better quality lens to compare it to yet, I'm concluding that this is showing my older lens to be less, sharp at times. I'm wondering if that is correct? This is my first interchangeable lens camera, and am learning a lot, about many different things. I'm a person who isn't so great at being taught things, but rather I need to dig in, and figure things out on my own.
Jeff Troiano is offline   Reply With Quote
Old November 17th, 2011, 01:29 PM   #92
I'm not sure your conclusion are OK. The peaking system on the FS100 is OK at best. It needs very good and clear edge and no movement to show the peaking indicator. Low is unreliable and useless. Med should be your setting in my opinion. But this peaking is a joke. Miles away from a true peaking found on ENG view finder.
By the way the peaking function in Zacuto and SmallHD EVF is closer to the ones on pro ENG viewfinder, and much more usable. You should get one.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old November 17th, 2011, 01:42 PM   #93
Thanks for the feedback. An external monitor is on my shopping list. For use on my camera, and also for use on the steady cam and crane. I was thinking the dp6, as opposed to a smaller one.
Old November 22nd, 2011, 12:12 PM   #94
I found Jean-Phillipe's comment to be very true, particularly on wide landscape shots. The difference between razor sharp and slightly soft is often undetectable by the camera's peaking, especially true when the lens is focusing near infinity..
Alister Chapman once commented that the infinity setting on some lenses, particularly prime lenses designed for still photography, are often variable from lens to lens. He was referring to the fact that a lens could focus passed the infinity mark, yielding an unsharp image.
Chuck Fishbein is offline   Reply
