Which head for Slider and Tripod?
Hi guys,
I am looking at getting a new head for a tripod and slider. I was looking at either the Manfrotto 501hdv, 502 or 701. Because this will have to support an FS700 I thought that the larger 501 or 502 would be better. Now the 502 looks like the improved model. However, I'm not sure if there is a quick release system that I can use on the 502 head that can also be used on a Glidecam. With the 501 head there is the 3433PL 577 Rapid Connect Adapter. Amazon.com: Manfrotto 3433PL 577 Rapid Connect Adapter with Sliding Mounting Plate: Camera & Photo Does anyone know of a system that would work for the Glidecam and the 502 head? Otherwise i'm just going to get the 501. Or to completely confuse, for the slider, should I actually be looking for a ball head? Thanks, Richard |
Re: Which head for Slider and Tripod?
I recently purchased this ball head for my slider. I like it very much.
Yeah.. cool little ball head.
I'm coming back to the idea of a fluid head however, and the 502 saga. Is there a quick release plate system for the 502 similar to the 577 rapid connect which is for the 701 and 501? Thanks, Rich |
I use the 701 with my setup, but since my normal head is a libec rh35 I needed a system that woul let me quickly change setups. I ended up with a bunch of these:
http://www.bhphotovideo.com/c/product/5563-REG/Manfrotto_394_394_Low_Profile_Quick.htmlMy setup is easily changed, bare camera, sticks, slider, rig with mattebox, slider on slicks etc... p |
