August 1st, 2014, 02:48 PM | #31 | |
Re: Sony PXW-X70 announced: Pro XDCAM version of AX100
Halve the time difference between successive frames and expect less difference between them - which any coder can exploit. Typically, the TIME between I-frames may remain the same (typically 0.5sec), so the no of frames between I-frames will be 30 for 60p, 15 for 30p. Same total number of I-frames. And since the I-frames tend to be much larger than difference frames, that's why 60p need not be a much higher data rate than 30p. |
August 1st, 2014, 03:29 PM | #32 |
On my FDR-AX1 30P, 3840x2160 has option for 60Mbps or 100Mbps and 60P is fixed at 150Mbps., 3840x2160 . 1920x1080 XAVC-S is 50Mbps. I think that since the 1920x1080 422 10bit is quoted at 50Mbps I would expect the data rates to be similar to the AX1? Maybe just like the AX100 30P 60Mbps.
Ron Evans |
August 1st, 2014, 03:43 PM | #33 |
August 1st, 2014, 03:55 PM | #34 | |
You need more than 3G SDi for uncompressed 4K. The FS700 manages to squeeze 4K over it's single SDI by using compressed raw. You can pass 4K 60p over HDMI 2.0. The lens appears to be the same lens as the AX100. It's f2.8 to f4, 9.3 to 111mm.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
August 1st, 2014, 04:06 PM | #35 |
Eventhough the specs say it's a f2.8 to 4.5 I just checked on my ax100 and acc to the info on screen it stays at f4.0 when fully zoomed in.
August 1st, 2014, 04:19 PM | #36 | |
August 1st, 2014, 04:29 PM | #37 |
Maybe the 4K upgrade is not just software but hardware upgrade to XQD card slots etc !!! Justifying the cost.
Ron Evans |
August 1st, 2014, 04:29 PM | #38 |
August 1st, 2014, 11:06 PM | #39 |
Still looking for low light performance on this. Stuff done with daylight seems just like all the rest done with daylight. The stuff is fine. But want to see low light performance.
Al Upper left hand corner of the map |
August 2nd, 2014, 04:45 AM | #40 |
Slash Rules!
anyone know how this compares to an ex1 or ex1r? that was always my "when i can afford it" cam (used obviously).
August 2nd, 2014, 05:49 AM | #41 |
Josh,
Alister mentions that it's not got the dynamic range of the PMW-300 (successor to the EX3 and EX1r type cams) in his initial review (he estimated at 10-11 stops area) and that it also suffers a bit from highlight clipping. So in HD mode I would EXPECT it to be not as good - especially bearing in mind the much lower price point - but then because of that 4K ready sensor it may well be as sharp - or even sharper. My C100 with its single, big "4K sensor" is certainly very sharp. So we're back to the "is dynamic range more important than sharpness" type debate. Mind you, it's current single sensor technology versus a 6-7 year old 3 sensor one. I'd always want more dynamic range - but that's just me. I stress I'm an ex EX3 owner/current owner of the PMW-300 and C100 (and TM900 still going strong) - but have never seen/handled this PXW-X70 cam in the flesh so take this for what it's worth... Pretty interested in it as a toe in the 4K world though - but doubt I'll buy it until 2015 (or something else as there will be other, perhaps better options by then).
Andy K Wilkinson - https://www.shootingimage.co.uk Cambridge (UK) Corporate Video Production |
August 2nd, 2014, 07:45 AM | #42 |
I'd be surprised if there's any significant differences between the AX100 low light and that of the X70.
August 2nd, 2014, 09:48 AM | #43 | |
Here is an AX100 4K low-light video: Here is a 4K video taken at night comparing the AX100 and the GH4: |
August 3rd, 2014, 06:03 AM | #44 |
I see the price of the FDR-AX100 and HDR-CX900 dropping here in Japan. $1,580 and $1,350 in stores and less on-line. Yamada-denki is not known for low prices, yet they show 10% discount.
Mark |
August 3rd, 2014, 03:41 PM | #45 | |
I pushed each camera to it's max by selecting a shutter of 1/25th for all camera's, I had a f2.8 lens on the gh4 and did the test shot at 6400 iso, the rx10 was set at f2.8 and had a iso of 12800, the cx730 had a gain of 24db and the ax100 a gain of 30db The difference between the cx730 and the ax100 was slightly in the advantage of the ax100 which had a bit brighter image but was a lot more detailed, the cx730 softens up a bit at max db while the ax100 retains much more detail The gh4 was a bit brighter then the ax100 but appeared a bit less detailed. The rx10 was the brightest of the bunch but also very noisy at 12800, at 8000 iso noise levels are acceptable and comparable with 6400 iso on the gh4 |
