More Tyro Idiotic Questions on XDCAM Transfer
I used XDCAM Transfer on a macbook and selected just about every category i could in preferences.
the outcome after "Import all clip" was some untitled directory on my external SATA drive with 2 types of files: 1. a MOV file that plays in quicktime pro 2. some XML file i kind of remember someone here mentioned some other file or some other directory structure, so i simply copy the whole BPAV directory from the SxS card next to the above untitled directory with the MOV and XML files. then i erase the SxS card for the next job. is this correct? what should i have done instead? thanks!!!! paul |
Still getting used to it
Hi Paul.
This is my workflow and it works for me although it has been a hard learning curve.... as simple as some may make it out to be. "plug in cam" :) I open and save a new project in FCP Open system settings and set everything to your project scratch, autosave etc click on import Files...xdcam out pops the xdcam browser with your clips in a random order (choose to sort clips by date modified so they fall into orer) I can't seem to make this permanent. select your clips and rename them using the clip title box click import I tought myself as I hate manuals. This has worked for me but I don't make any in out points with the xdcam browser software. I have monster HDs and just load everything. I also have raids and other back up disks so.... i'm not in laptop land. It has been recommended to burn your data to DVD DL's. I have tested rebuilding an entire project from regular DVDs. It was a little bit of a PIA (exchanging diks) but really quite easy! Please don't do what I did and rush the process. I lost a crucial clip by not quickly scrubbing down the line to see if everything made it in. Good luck and I hope I didn't add to the confusion. |
Thanks Mike.
so i did the import as you say under FCP6.0.3 and it created a MOV file and a XML file and placed both within the XDCAM transfer directory, in a directory i named.
now, how does this differ just using Sony XDCAM Transfer software and did the import just with that? also, if i simply copy everything inside the SxS during the session completely onto my MBP, wouldn't that be "FAIL-SAFE" as well? during a shoot, i may not have help doing imports and copying an entire SxS using the Apple Finder should be pretty straight forward and easy. right? paul Quote:
