Any workarounds for this Log and transfer bug
I found this thread about XDCAM Transfer but the problem I am having is with the FCP plugin:
http://www.dvinfo.net/forum/sony-xdc...clips-fcp.html The bug I am seeing is that the Log and Transfer Plugin for FCP always assumes mono mix for importing clips. It was unpleasant to discover this after importing a couple hundred clips. My FCP Sequence preset shows audio is set to Stereo but unless I click the audio tab of the L&T plugin and change it to stereo for every clip, the ingest imports the audio as mono. Has anyone figured out a workaround to this bug? I am using XDCAM_EX_Log_and_Transfer_Plugin_1_2_0 TIA |
Re: Any workarounds for this Log and transfer bug
1 Attachment(s)
forgot to attach sequence settings. I noted the Capture Preset is defaulted to Generic Capture Preset which acts as a dummy I suppose. Nothing in there matches what is being ingested.
That worked a charm Doug. Thank you
