"No support" in lens information? at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old December 6th, 2012, 12:04 PM   #1
Hello all,
I have a question about my pmw-f3 and the stock Sony lenses. When I attach them, the information tab found in the main menu just says "No support." Does anyone know why this might be? I tried this with another pmw f3 and did not have this problem. Both are on the version 1.4 firmware.
All help greatly appreciated.
Thank you,
~Omar
Omar Nabulsi is offline   Reply With Quote
Old December 6th, 2012, 12:53 PM   #2
Re: "No support" in lens information?
If lens data is turned on in the menu you may want to examine the lens mount for broken pins. It has been a common issue with the Sony PL adapter.
http://www.LandYachtMedia.com
Old December 6th, 2012, 10:55 PM   #3
Thank you for the reply. I checked the pins on the PL mount and all eight of them actually seem fine. Any other ideas? I wonder if it is a software issue rather than a hardware issue.
All help appreciated.
Old December 7th, 2012, 03:49 AM   #4
Make sure the lens data type is set to Cooke /i, which is what stock Sony lenses have. If it's set to Arri, then you get that message.
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old December 7th, 2012, 05:56 PM   #5
Interesting, can you tell me how I would do that? I am not very familiar with the menus, and I did not see an option for that when I looked.
Thank you.
Old December 7th, 2012, 06:52 PM   #6
Never mind, I got it. That was it! Thanks David. For anyone else reading this, it is located under the main camera menu in the "Lens IF" setting.
Thanks again.
