Older 1/2" JVC-lens on F330? at DVinfo.net
Old September 8th, 2009, 02:16 PM   #1
I recently bought a second hand PDW-F330 camcorder. Most of the time I use it in SD/DVCAM 16:9 widescreen mode. For very little money there are some older wide angle lenses around meant for e.g. the JVC DV-500. For example:
Marktplaats.nl > Prof. lens voor o.a. JVC, Panasonic, Philips 1/2 inch camera - Audio, Tv en Foto - Professionele Audio-, Tv- en Video-apparatuur
Is there an option to fit this lens on the F330 and how would it perform? Can I connect the lensconnecter to my camcorder or uses JVC a different connector? Will it fill 100% of my sensor (no black corners)? Does an older lens just knock down the quality of XDCAM or would it probably work better than you would expect?
Gabor Heeres is offline   Reply With Quote
Old September 9th, 2009, 12:48 PM   #2
The Panasonic 1/2" mount is different to the Sony mount, so it won't fit. You can use 1/2" SD Sony mount lenses. The higher quality ones work reasonably well.
Alister Chapman is offline   Reply
