S-Log and Slomo - Page 2 at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old September 12th, 2012, 07:01 PM   #16
Re: S-Log and Slomo
Originally Posted by Douglas Villalba View Post
The f3 doesn't do 1080p60 internally and it only it with full slog upgrade out through dual link.
totally true!
Jose Rodrigues is offline   Reply With Quote
Old September 12th, 2012, 07:39 PM   #17
Re: S-Log and Slomo
Sorry about that. I just saw 4 figures ending on 80 and I assume 1080. It is usually 1080 or 720.
I have to check on S&Q when I get to my camera. I know it won't go lower than 17 fps at 1080 after the 1.4 upgrade.
Douglas Villalba - director/cinematographer/editor
Miami, Florida, USA - www.DVtvPRODUCTIONS.com
Douglas Villalba is offline   Reply With Quote
Old September 13th, 2012, 01:09 AM   #18
Re: S-Log and Slomo
That's incorrect. If you set the camera to 60i/50i and set the "Dual Link & Gamma Select" to "1.5G YPbPr & Video" you will get 60p/50p on the A and B dual link outputs, even without the CBK-RGB option.
So a standard, non S-Log F3 can output 60p/50p via dual link.
The bigger problem is the lack of recorders that can record dual link 60p/50p.
Old September 13th, 2012, 02:20 PM   #19
Re: S-Log and Slomo
That is correct. One use I can see is on food shoot connected directly to a computer with a dual link card.
I've never done a test but I know that Timur Civan did a test a while back.
Old September 13th, 2012, 02:26 PM   #20
Re: S-Log and Slomo
Don't you needed the CBK-RGB option to activate the B output?
Old September 13th, 2012, 06:06 PM   #21
Re: S-Log and Slomo
No. You only need it for RGB 4:4:4. It will output 4:2:2 YUV @ 60p without the option.
http://www.LandYachtMedia.com
Old September 13th, 2012, 07:11 PM   #22
Re: S-Log and Slomo
Which recorder can record dual link 60p/50p in full HD? I work with Adobe CS6 on a windows platform
Thanks Rudy
Rudy Wilms is offline   Reply With Quote
Old September 13th, 2012, 08:16 PM   #23
Re: S-Log and Slomo
Thanks Rudy
Cinedeck
cinedeckEX / cinedeckRX
Ryan Hollings is offline   Reply With Quote
Old September 14th, 2012, 12:24 AM   #24
Re: S-Log and Slomo
Convergent design Gemini 4:4:4. Great recorder and a good price!
Gemini 444 | Convergent Design
Ron Aerts is offline   Reply
