Samsung Monitor Suggestions??
Hi,
After reading tons of reviews, it seems that Samsungs are pretty hard to beat. If you use a Samsung monitor for video editing what would you suggest and what to stay away from? I want to setup a two monitor system one for editing with the other for viewing. I need both monitors to be capable (switchable) of viewing 4:3 and 16:9 aspect ratios correctly. I am currently looking at the following monitor, but I've heard that TN monitors are a no no. Is this true? Other than that I like the specs; 2ms, digital/analog interface, etc.. Please give me your professional opinion. Camcorders that I use are the Sony DCR-VX2100 and the Sony HDR-HC7 Thanks, Ray P.S. I know about the "S" and "A" series issues on this particular monitor. S is preferable. Samsung 226BW Panel Type: a-si TFT/TN Viewable Size: 22.0" Wide Pixel Pitch: 0.282mm Brightness (typical): 300 cd/m2 Contrast Ratio (typical): 3000:1 DC Response Time (typical): 2 ms (G to G) Viewing Angles (H/V): 160/160 Native Resolution: 1680 x 1050 Aspect Ratio: 16:10 Maximum Color: 16.7M Interface: Analog/Digital Input Video Signal: Analog RGB, TMDS Digital Link, DVI Sync Type: Separate H/V, Composite, SOG Input connetcors: 15-pin D-sub, DVI-D Plug and Play: DDC 2B Power Consumption: 55 Watt (max.), <2 watt (DMPS mode Stand Type: Simple Cabinet Color: Piano black VESA Wall Mount: 100 mm Magic Technologies: MagicTune with asset management, MagicSpeed, Magic Contrast, MagicBright 3 Special Features: DVI (HDCP), Swivel and tilt Dimensions (W x H x D): 20.3" x 16.6" x 8.6" |
Your Samsung should be fine. Many of the Samsung models are not very adustable, which is an absolute requirement for me, and a common complaint for those who purchase the non-adjustable models. I notice your model is not height adustable. I couldn't live with that myself.
The differenced between many of the good monitors out there are, to me, mostly boil down to preference. If you notice the reviews for most monitors, people rave about almost every model because they are usually upgrading from an old monitor. Samsung monitors are popular, but so are HP and Dell. Go to a store and look at them to gain an idea of what is best for you. Selecting a monitor must be done by looking at them, not just reading about them. I looked at the Samsungs and personally wan't impressed. I liked other models more, but that is just me. |
I have the Samsung 206BW monitor (20") on my computer and I'm very happy with it. I don't think you can wrong with a Samsung monitor, they're really nice. On the other hand, when comes the times to do color correction and other type of filtering in Vegas, I'm using a 26" Samsung LCD TV (#LN-T2642H) as a second monitor.
I'm not an expert as to tell if it's the right way to go but all I can say is that there's a HUGE difference between the computer monitor and the TV on every possible aspects you can think of. Maybe I could calibrate my monitor so it looks exactly like the TV but I doubt. Once I burn a DVD of my project and watch it onto my high def CRT TV in the living room, I can say it's much closer in terms of colors, contrast, and filtering to my Samsung TV than it is to my computer monitor. This is why I'm never relying on what I'm seeing on my computer monitor. Hope this helps, |
Hi Everyone,
Thanks for all the replies! Well, here is my latest find; A Samsung 2253BW 22" monitor which I'm told replaces the 226BW. The PDF on this model is can be found at the link below. What I like about this monitor is the ability of using it as DVI or Analog RGB. Correct me if I'm wrong, if I was to have two of these one setup as a main monitor with the other setup as analog would'nt the analog monitor be close to what you would see on a TV? If so, I could use the analog setup for color correction during editing. One of the things I like about this monitor is that it is switchable for differant aspect ratios which is explained in the PDF below. Another scenario which may be much better is to use this monitor as a monitor and use a LCD TV such as the Samsung Series 4 450 for viewing/editing purposes. This LCD TV is also 22". The link for this LCD TV is also found below. I know I probably sound a little ignorant on this, but I want to know which would give me the best setup for video editing. This is why I'm turning to you folks that are experienced for your help. I appreciate all of your input and help.Thanks, Ray P.S. I tried to add the PDF files from Samsung, but was unable to. |
What about a Dell Ultrasharp 2408WFP?
I looked at Samsung's as well but in the end went for this Dell. I'm VERY happy with it :=)
I believe the LCD panel in it is either a Samung or LG one anyway and, at 24-inches (plus my secondary monitor for previewing video) this one is just a joy to work on for editing! I thought very hard about 22-inch monitors but I'm really glad I went for a 24-inch one. I also suggest you dig around in the monitor section (where the link below was originally posted) as there may well be more info on there which you'll want to read about various monitors people are using and recommendations etc. http://dvinfo.net/conf/showthread.php?t=116972 |
If you deliver to the TV (DVD or Blu-ray), rather than to the Internet, I recommend using a TV.
I use a Sharp GP1-series 1080p TV as my video monitor at work and couldn't be happier. The color curves on the Sharp TV and the Viewsonic monitor are quite different. Dark blues on a monitor are mid blues on a TV. Disclaimer: I work for Sharp Labs of America. (Regardless, I can highly recommend Sharp's 32" 1080p TVs for editing. They are not video reference monitors though. That's another class of product altogether...) |
Hi Guys,
Thanks for your input. Sounds like a LCD TV is the way to go in regards to viewing/editing purposes. Now that I think I have a Monitor and TV picked out, I'm wondering about the connectivity to a graphics card. The monitor and TV connections are the following; Samsung 2253BW LCD Monitor DVI Analog RGB Samsung Series 4 450 LCD TV 1 HDMI (HD Multimedia) Interface rear Component video: 1 (Y, Pb, Pr) A/V inputs: rear S-Video Input: rear RF antenna input: rear Headphone jack: rear PC D-sub: rear I want to use the LCD TV for viewing during editing in order to get the colors as close as possible for final dvd burning. My videos are primarily used for SD and HD television. Will the Nvidia Quadro FX3700 accomodate both the monitor and TV with the connections shown above? This card has Two Dual-Link DVI Output Ports. Would I need a certain type of cable for connecting to the TV? If so, please give me the info needed for the correct cords to use. As you can see I'm a little ignorant when it comes to the connectivity, but I want to make sure I get the right card to accomodate this monitor and TV. Your help will be most appreciated! Thank you, Ray |
