RAM render falters . . ?
Try this one for size ! ! ! !
1/- Put a Jpeg on a t/l 2/- Pan/Crop a couple of rotations 3/- Select Event 4/- Build Ram PV 5/- I get 2 frames. . .. here's the killer .. . please try it to confirm I'm NOT going bonkers . .. 6/- Copy the same event with the rotations in it. 7/- Paste back somewhere on Time Line 8/ NOW Build Ram PV! .. . GOT IT! 9/- Go back and try and Build Ram PV . .result? Only 2 frames . .. weird! Grazie . . taking medication . . . |
I was trying to do this as well, but got two questions for you:
1. which exact version of Vegas? (I'm using 5.0b) 2. what is the exact name of the function you are using for rendering previews, because I've got (under Tools menu): - Preview in Player - Selectively Prerender Video - Build Dynamic RAM Preview (grayed out here) 3. what are your project settings you are using? |
"I was trying to do this as well, but got two questions for you: " well actually you've possited 3 in total HAHAHA! ! !!
OK: 1. "which exact version of Vegas? (I'm using 5.0b)" 5.0b Build 160 2. Build Dynamic RAM Preview - NOT greyed out here. 3. "what are your project settings you are using? " PAL-DV; 720x576; 1000mb for RAM Preview; Frame Rate 25.00 (PAL) . . .anything else? Grazie |
I'm sorry but I seem unable to test this. My dynamic RAM preview
stays greyed out (yes, I increased the memory it could use for this to 512 MB). I've never used the feature before either, so I have no real clue as to what is going on.... |
I was going to post a question about why sometimes I go to RAM render and I end up rendering only a few frames or so when I saw this post. Sometimes it works well, sometimes it doesn't work at all. I have 1.5 Gigs of RAM.
I see no relation between when it does and when it doesn't. I will sit back and see if someone joins in with a solution. |
Do you have any ideas Edward?
Hello Edward!
Charley & Rob - thanks for showing the interest .. . All we need is to wake up Edward and we could play some Holiday Bridge. 2 Clubs . ..
But yes, I get 2 frames and then it falters. Copy and paste it down the T/L and it works nice as pie. . .. Grazie |
Obviously it's telling Grazie that the picture doesn't belong there. Instead he should be placing it farther down the timeline! :-)
So, Grazie, what's the footage you SHOULD be placing at that location???? :-) Honestly have no idea why ram render would not work for the same image in one location but work in another. I almost never use ram render anyway. Does a full render work there? Or a pre-render? Or a render to new track? |
Hiyah Edward,
. . hold on just firing up the MONSTA! . . I'm really suffering with a nasty sore throat .. anybody got an OLD time relief remedy? . . Okay . . MONSTA! is awake . . grabbing hold of Vegas . . New Project . . "Does a full render work there?" Yes. "Or a pre-render?" Yes. "Or a render to new track?" - Yes. Repeating experiment . . 1/- FXs aren't the culprit 2/- BUT when I use P/C and try and RAM Render = 2 frames! 3/- Just copied this same event further dpwn the T/L and RAM render works! 4/- Now stick another FX on this P/C and it works too! Throat still sore . . I'll be on pain killers in a couple of minutes. Don't wanna touch Penicilin quite yet .. . Grazie |
WHERE on the timeline?
The only thing you added is Pan/Crop? What if one of US tries the VEG (you just would need to tell us the timecode range to ram render)? |
. . sorry Edward . . just repeating . .
1/- Event STARTS at 00:00 total length 00:00:18.02 sec AVI 2/- P/C introduced 00:12 . .simple move right 3/- This works in Preview .. BUT! 4/- Highlight as per doing a RAM render, I get 3 frames and then it faulters .. 5/- Copy the same Event and Paste to around 00:01:00 . .ie 1 min marker . .and RAM renders work! 6/- NOW delete original EVENT at 00:00:00 and PASTE back the COPIED event and this now works at 00:00:00 Totally weird! p.s. I do have 1gig of RAM given over to RAM renders Grazie |
Very strange. Tried to do something similar here - didn't get it to fail.
Oh . . .. . ?
Now, look over my shoulder and you'll see what I mean .. .See! There it is again! Grazie |
Darn, I must have blinked.
. . .I can do it at the drop of a hat . . and again! . .and again! . . . .
