Rendering Help
I'm trying to get a decent render directly from a .MOV file from my T2i. These are all tests as I barely know what I'm doing. I've tried a variety of formats. So far, I'm experiencing moire in a blue textured shirt and on most formats, stuttering. I have a brand-spanking new 920 (stock) with 6GB RAM on a GTS250. I can play the MOV files natively and pile on quite a few effects and transitions before it begins to bog. So, I know the computer is not stuttering.
My first goal is to render to HD just so I can watch the results. Second goal -- upload to web. Third goal -- create DVDs for friends, probably SD as Blue is too spendy for me. At the moment, I'm getting best results with wmv format. Your suggestions are very welcomed! Thanks, Burt |
Interlacing will cause that moire pattern. Fine lines and interlacing do not mix well.
T2i produces non interlaced. Correct me if I'm wrong. I assumed all files were progressive.
All files are not necessarily progressive. Your T2i files may be. But the project settings may not be. The rendered files may not be.
