Light shift with Cineform
I posted previously that I am going to go back to 9e for now as I can't seem to resolve an issue with 10. When using cineform and inserting transitions between scenes I find that there is a distracting and abrupt light shift at the beginning and end of the transition.This issue has not been resolved. Vegas 9 handles Cineform correctly without this abrupt and annoying light shift.
Re: Light shift with Cineform
Mervin,
I believe I've seen the same problem when editing in 8bit mode. If you render in 32bit mode I think it works ok. You should file a ticket with Cineform, they very resposive to bugs in their program. More than any company I know of. |
Unfortunately that does not work for me. I always render in 32 bit mode. Everything in Cineform FilmScan 2.
I don't think its a Cineform issue. I think its a Vegas 10 issue. Vegas 9 is fine. |
Got it, I'll have to keep an eye on this. Sony's support for Cineform has been less then stellar. I've been struggling with a Vegas project trimmer bug involving Cineform for over a year and while seemed Sony finally fixed it I've been having problems again archiving projects.
sorry if I bore those of you who have read my previous posts regarding various versions of Vegas, but I always edit in 8c and render in 9e-64 bit. Why? Almost never any type of glitch or unwanted surprise.
I do use Vegas 10, but only for BCC7 & (now) white balance. But I immediately render to Cineform and put the .AVI on the TL in 8c. Seems to work well - but haven't done that procedure often enough to know for sure. |
Hi
Have you tried using the 32bit full colour levels in Sony rather than the 32bit video levels, that might help. Also Cineform may have some settings for adjust what levels it uses. Regards Phil |
OK I've had a bit of time to experiment. With Vegas 9 I do not get a light shift whether I edit in 32 bit video levels or full range. With Vegas 10e there is an abrupt shift when using Cineform, especially when the looks are used. It may not happen if I import the original files and then convert to cineform (need to check) but that defeats the purpose of using cineform (color grading).
This is a vegas 10 problem and its not fixed. So back to 9e. Can I get my money back? |
Mervin,
Make sure you file a ticket with Cineform. If it's a problem on their end they will fix it ASAP. Keep us posted as I am editing a Vegas 10 Cineform project right now that I will be rendering soon. Thanks, Marc |
Not a Cineform issue. Works with vegas 9. How does one file a ticket with Vegas?
To file a ticket with Sony go here Sony Creative Software - Forums - Vegas Pro - Video and under "my Account" you'll see a "my support" section.
Since Vegas changed the way it works with Cineform in version 10 I would still check with Cineform as well because Neo HD 4 does not work with Vegas 9 so Cineform must have changed some things as well. Keep us posted, Thanks |
