From Vegas to HandBrake at DVinfo.net
Old August 13th, 2014, 02:24 PM   #1
Some time ago I built a workflow which simplified the process of rendering an intermediate out of Vegas to use in HandBrake for a better AVC encoding (often I'm just not happy with the quality of AVC renders out of Vegas, especially if it needs downscaling).
I finally found a way which needs only one mouse-click in Vegas Pro to get the current project send (via frameserving) to HandBrake. Though the inital installation and configuration will need some time – the use of what I call "Vegas2HandBrake" is really simple, look here:
It was done for my personal use only but then others found it useful too, so if you're interested - take a look at the description of installation, configuration and use of Vegas2HandBrake at VegasVideo.de.
Marco Ba is offline   Reply With Quote
Old August 17th, 2014, 10:21 AM   #2
Re: From Vegas to HandBrake
System requirments:
Windows 7, 8 or 8.1 – 64 bit.
Vegas Pro 13 or 12.
Maybe it even works on Vegas Pro 11 64 bit (I can't test though).
Old August 19th, 2014, 11:33 AM   #3
Old Boot
Like a charm. No more F!"$""£%$ interim renders to HB.
"MARCO FOR KING OF THE UNIVERSE!"
Grazie
Old August 23rd, 2014, 06:51 AM   #4
:D
Some people had trouble with the installation of DebugMode FrameServer, thus the FrameServer did not appear in Vegas Pro's renderer list (and thus the Vegas2HandBrake workflow would fail).
So anyone trying this workflow: Be sure you selected the correct version of DebugMode's FrameServer. 2.15 for Vegas Pro 13 and 2.14 for Vegas Pro 12 or 11 (remember the Vegas2HandBrake workflow will not work with Vegas Pro versions prior to 11).
Whereas there should be no need to modify the installation path of FrameServer's core, be sure the installation path for the FrameServer's Vegas Pro plug-in will be set to the program folder of the appropriate Vegas Pro version.
If you use Vegas Pro 13, Vegas Pro 13 was installed to the standard path and you install FrameServer 2.15, there would be no need to modify anything during installation of FrameServer. But if you installed Vegas Pro 13 to an individuall path, you also need to adapt the path of the installation of the FrameServer plug-in (not the core).
If you don't use Vegas Pro 13 and you install FrameServer 2.14 you must be very careful because during the installation process the FrameServer will give you the standard path to Vegas Pro 11 only. So if you use Vegas Pro 12 you must modify the given path of the FrameServer plug-in (again: not the core) to your Vegas Pro 12 program folder.
Hope this helps avoiding trouble.
Old September 14th, 2014, 12:42 AM   #5
Marco,
Thank you for your superb work on this script. It works like a charm.
Marc Salvatore is offline   Reply With Quote
Old September 21st, 2014, 04:39 AM   #6
few hic ups getting it going.
But have to say Thank you
A real time saver.
Thanks again :)
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply
