Sony DCR-HC Series - Heaven or Hell? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old March 13th, 2006, 03:06 AM   #1
I found this series of consumer camcorders while looking for a personal camcorder today and fell in love with them. I own several Canon GL2's, but I wanted something smaller and less expensive. This series fits right in my palm pefectly and seems to get a pretty good image.
Does anyone own one of these (specifically the Sony DCR-HC26) and what are your thoughts? Especially what are your experiences with LCD touchscreens; ie, do they damage more easily since you are touching them?
Black Label Films
www.blacklabelweddingfilms.com
Travis Cossel is offline   Reply With Quote
Old March 13th, 2006, 09:27 AM   #2
No problem whatsoever with the touchscreen. It doesn't take much force to press a button. I own a couple of HC1000s and am not really bothered by the lack of buttons and wheels on the outside of the camera. If you set your shot up before you start filming, like you're supposed to do, then having a touchscreen really doesn't matter. You're more likely to wear out a button or a wheel. Plus, the touchscreen can be calibrated on my HC1000s.
Stephen Finton is offline   Reply With Quote
Old March 13th, 2006, 12:35 PM   #3
Cool. The touchscreen was my real concern. I haven't heard anything about their durability, so I was a little concerned. I'm not too worried about setting up shots or anything. This is for personal use only, so I don't expect to be fiddling with the controls a whole lot.
What did you mean about calibrating the touch screen?
Black Label Films
Old March 13th, 2006, 01:51 PM   #4
I think it is in case the pad and display drift. If you find yourself pushing buttons slightly off center, then you can realign where the grid registers the push underneath the button.
I haven't tried it yet because it's pretty spot-on as it is. I'm curious now, though. Wondering if it has a "sensitivity" setting, too.
Seriously, though. I don't know if this is a standard setting for all touchscreen SONYs. The HC1000 teeters on the brink of prosumerism.
Old March 13th, 2006, 02:16 PM   #5
Ahhhh, okay. Thanks!
Black Label Films
Old June 2nd, 2006, 11:15 AM   #6
Sony DCR-HC26
Hi,
I am not a technical person.
I bought this Sony DCR-HC26 two weeks ago. I have a I-link cable at home and connected this cam with my PC after installing driver cd (which came with sony package).
I tried my best but could not connect Cam with computer.Please let me know how should I solve this problem.Thanks
Davis Michael is offline   Reply With Quote
Old June 2nd, 2006, 11:33 AM   #7
I haven't used the camera with my computer. I use my GL2's for transfer. Wish I could help you more.
Black Label Films
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
