Producing 3D files in AviSynth - Page 2 at DVinfo.net
Old June 7th, 2010, 02:51 PM   #16
nokia is giving for free a MVC 3d encoder, you just need to compile it.
Mobile 3D Video | Nokia Research Center
Old June 7th, 2010, 04:13 PM   #17
Originally Posted by Adam Stanislav View Post
I would say it is the player that creates that format (not file format). The reason for it is that you cannot store that format in a 4:2:0 MPEG file because those files must have an even number of lines (or even a number of lines divisible by 4), but that HDMI format always has an odd number of lines, which is double the number of lines in each view plus 45.
Thanks for your information and Pavel Houda's who I couldn't quote in my reply. I use Sony Vegas and had tried using it to combine a couple of files produced from A Fuji 3D camera to no avail. But the subject of the HDMI file format and what is encoded on a Blu-ray disc is of interest even though I know the authoring program is the one that would ultimately generate the proper code. Steve Shovlar's question seemed to be about the same overall topic so I was looking for some more clarity. I will take a look at Pavel's link and maybe a lot more will become clear. Thanks to both of you, especially Adam for pointing out the avisynth program.
Steve LaPierre is offline   Reply With Quote
Old June 7th, 2010, 05:24 PM   #18
Originally Posted by Pavel Houda View Post
I don't want to start another complaining avalanche if that is right or wrong
Maybe you should! For a technology to be widely accepted, its specs should be available for anyone. BD may be cutting the branch it is sitting on by staying secret and proprietary.
Someone will come up with a public spec for a different technology accomplishing the same, and then it will be bye-bye bee dee!
Adam Stanislav is offline   Reply With Quote
Old June 9th, 2010, 09:00 AM   #19
Pavel thanks for the link that was very informative and a surprisingly short read. For some reason your posts won't allow me to quote them but this is relative to the Tom's Hardware link on Blu-ray 3D. I can see where the authoring of a Blu-ray 3D would be quite complex to create that second view data.
Old June 9th, 2010, 02:09 PM   #20
Hi Steve, you are very welcome. The whole concept is not very hard, but the current standards need to be extended, because somehow they have to pump twice the # of pixels at the same frame rates, which taxes the hardware, and bandwidth of the existend delivery systems. That is why they either lose half the pixels or come with different, more efficient compression schemes, like the MVC, and then there is no inexpensive authoring and delivery systems for those schemes, at least not yet. It will take a while. I don't know why the system doesn't allow quoting me, maybe it is a hint for me to talk less.... :-)
Pavel Houda is offline   Reply With Quote
Old June 9th, 2010, 09:32 PM   #21
I have just added some illustrations to the documentation. This should make it easier to understand what the basic functions do.
Old June 9th, 2010, 10:52 PM   #22
Thank you Adam,you are the greatest!
Old June 10th, 2010, 06:58 AM   #23
Oh, you're making me blush.
Seriously, I am glad you find it useful.
Old December 10th, 2010, 06:32 PM   #24
Hi Adam,
Thanks for your tool but i couldn't try it.
I gave it a go with left, right-eye videos demuxed from some of my 3DBDs since i don't have my own 3D left, right videos for the time being. (i don't have 2 camcorders or any new gen. 3D camcorder to shoot yet.)
First i created left avs and right avs.
left.avs:
DirectShowSource("C:\test\left_v.h264", fps=23.976, audio=false)
right.avs:
DirectShowSource("C:\test\right_v.h264", fps=23.976, audio=false)
And final avs:
Import("C:\Program Files\Pantarheon\Pantarheon 3D AviSynth Toolbox\Pantarheon3D.avsi")
lv = DirectShowSource("left.avs").ConvertToYUY2
rv = DirectShowSource("right.avs").ConvertToYUY2
HDMI3D(lv, rv)
And when i tried to open the final avs with MeGui i got this popup:
"Left and right clips must be of the same size!"
I checked out and i met:
Same duration,
Same frame numbers,
but right video is always shorter than the left video as file size!
Weird.
What am i missing?
Thanks in advance.
EDIT: OK, i've found i have to re-encode right-video before processing.
Seref Halulu is offline   Reply With Quote
Old December 11th, 2010, 09:02 AM   #25
Good. I'm glad you found the answer.
Old December 11th, 2010, 07:29 PM   #26
Thanks but not sure since i haven't been able to re-encode the right-eye video as for now.
Old December 11th, 2010, 10:50 PM   #27
OK, I have received your email and I think you are misinterpreting the "same size" here. It refers to the size of the image. Both have to be the same, that is have to have the same dimensions. So, for example, if the left view is 1920x1080, the right view has to be 1920x1080 as well. But the files do not have to have to have the same number of bytes in them because image compression is highly unlikely to give you that.
Old December 12th, 2010, 03:10 PM   #28
Thanks for the clarification.
Now i got the right_out.264 file and tried lots of permutations on command line.
But i always got 25 fps instead of 23,976. Here is one of them:
"C:\H264StereoSource_a2>x264 --level 4.1 --crf 20 --tune film -I 24 --b-pyramid none --sar 1:1 --aud --rc-lookahead 24 -o right_son out.avs
avs [info]: 1920x1080p 1:1 @ 25/1 fps (cfr)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264 [info]: profile High, level 4.1
An unintentional loss of pictures occurs! Exitb/s, eta 0:00:12
A gap in frame number is found, try to fill it.
RefPicList0[ 2 ] is equal to 'no reference picture'
Anyway i converted it to 23.976 back while remuxing with TSMuxer.
And tried to open my final avs with MeGui:
"Import("C:\Program Files\Pantarheon\Pantarheon 3D AviSynth Toolbox\Pantarheon3D.avsi")
HDMI3D(lv, rv) "
And i got the same popup:
"Avisynth Script Error:
Left and right clips must be of the same size,
bla,bla..."
This is why MeGui doesn't accept MVC or can i open and re-encode this frame-packed stuff in Premiere CS5 or Sony Vegas?
Old December 12th, 2010, 08:03 PM   #29
You can open pretty much anything in Vegas. And as of v.10, it can handle 3D natively, so you do not even need to go through AviSynth at all. And previous versions of Vegas can handle 3D through my Bororo 3D plugin. It is much easier to use Vegas than to use AviSynth because you get to see what you are doing while you are doing it. You just import your left view and your right view and Vegas will combine them for you.
Old December 13th, 2010, 02:53 PM   #30
Thanks but most of the hobbyists need a free MVC encoder and i think your tool + avisynth script + free MVC encoder would be great.
I used to uıse Premiere CS2 in the past but i mostly needed to use avisynth and Cineform.
