Producing 3D files in AviSynth - Page 4 at DVinfo.net
Old January 19th, 2011, 06:30 PM   #46
OK, finally i got it.
Seref Halulu is offline   Reply With Quote
Old January 27th, 2011, 10:33 AM   #47
Recently discovered your plug-in for AviSynth and I absolutely love it. It saves me a really big hassle. I'm using the open-source renderer POV-Ray to create 3-D animation out of individual left and right frames stored in .PNG files. Using AviSynth as successfully created either side-by-side or top bottom 3-D files that look beautiful on my new Samsung 3-D TV.
The problem of course is I'm only getting half resolution. I understand everything you said in this thread about the inability of MPEG to be used for HDMI 3-D format with the odd number of lines. But my question is so what do I do about this?
I can browse files on my PC using DLNA from the TV but it doesn't recognize .avs as a valid video file. I can play the file using Windows media player because it recognizes it as a stream but the TV can't handle it.
I can create AVI and MPEG using TMPGEnc 4.0 XPress and transfer them to the TV on flash drive but I've got the MPEG problem and I don't really know of any AVI codecs that will do odd numbers of lines.
You created the HDMI3d option was something in mind. What do you do with such files to display them if you can't convert them into any kind of file formats? Is that option in your toolbox just for demonstration purposes or do you really have a practical way to use your toolbox and AviSynth to display files on actual TV?
You've implied that there some sort of RGB format of AVI file that will handle odd numbers of lines. What codec do you suggest and what conversion tool would you use to create such a file?
Chris E. Young is offline   Reply With Quote
Old January 27th, 2011, 02:53 PM   #48
Take a look at Stereoscopic POV-Ray. This will allow you to create full size side-by-side images with POVRay. There is only one problem with it that I have noticed: If you try to save to PNG with an alpha channel, the alpha channel is only saved to the left view. But if you do not need the alpha channel, this software is quite amazing. Here is a video I made using it: YouTube - Pebbles - 3D. I exported everything to PNG, then rendered with Sony Vegas (and probably my Bororo 3D plug-in since Vegas did not support 3D natively at the time).
Theoretically, any RGB format should handle odd numbers of lines.
As to how to watch the files, personally I use TotalMedia Theatre 5 with an nVidia card and active glasses. Many others use Sterescopic Player which seems a bit more flexible.
Adam Stanislav is offline   Reply With Quote
Old January 27th, 2011, 03:08 PM   #49
It doesn't surprise me that someone has come up with a stereoscopic version of POV-Ray. I probably should've gone looking for it. Although I've got a pretty good system going right now using your toolbox and simply combining the PNG files after rendering. Of course if I'm going to do side-by-side or top-down and adjust the aspect ratio before rendering and I don't use the "Reduced" version of your tools.
I've tried DivX and Xvid codecs to create odd numbers of lines. It can't be done. Be specific what codec should I be using.
By the way the viewing tools you suggested will not help me because I don't have a 3-D capable video card in my PC nor do I have a 3-D capable 120hz or greater monitor. All I have is my Samsung TV where I can use DLNA or copy something to a flash drive.
Old January 27th, 2011, 06:18 PM   #50
Gosh, that's not mine to say. Codecs are like religions. If you choose one for someone else, you start a war. :)
Anyway, I have not used an RGB codec for years, but back when I did, I was quite happy with the one that came with Camtasia as it was a non-lossy codec.
I do, however, have to ask why you would be using an odd number of lines. No standard video / monitor / TV size uses one. They all have an even number of lines. With POVRay I would always use 1920x1080 lines (i.e., 1080p) unless I needed to go higher (e.g., 2K) but so far I never needed that. I tend to export to 16-bit PNG files (an overkill, perhaps), then combine everything usually to a 24 fps 1080p mp4 video. And when I say 24 fps, I mean 24 fps, not the dreadful 24 / 1.001 fps, which I hate profoundly. I am not telling you to do that, only saying what I usually do.
Old March 10th, 2011, 01:26 PM   #51
Re: Producing 3D files in AviSynth
if you want compatible 3D, there is no codec war, you just need to choose the winning team for you.
for me, i want mvc because i want full HD from a blu-ray disc.
if you can manage to get SbS at half res on BD, you can go with more codecs.
if you are happy to play from some hardware or software media player, then you can choose almost anything.
for instance , i got only 2 choices, the free nokia or the free JMencoder MVC encoder.
(the latest being used by sony for their ultra expensive apps).
Since Sony and JVC are releasing consumer level camera encoding 3D on MVC, we can expect soon some cheap utility to transfer video from camera to pc and back using that codec.
Old March 10th, 2011, 01:45 PM   #52
and just about these consumer 3d camcorder (currently JVC and Sony).
These guys suffer the same illness from everybody because if they put an MVC format in their cam , they use 1080i50/60 instead 1080p24, so good by for compatibility with the 24p of BD.
Old July 7th, 2011, 03:27 PM   #53
Hi Adam, hope you've seen this:
Doom9's Forum - View Single Post - 3D Toolbox
best!
Old July 7th, 2011, 05:05 PM   #54
No, I did not see it (I totally forgot I was even a member of that forum). Thanks for pointing it out.
And no, I have no plans on working on the script in the near future. My health was failing for quite a while. We are finally finding the right combination of medications to control my diabetes, so I am starting to feel “normal” again, but I am taking it easy.
Plus, I have started working on a completely different project, this one dealing with color grading, though I am not going to go into any details about it because with my health I do not want to make promises and not deliver them.
Old July 7th, 2011, 05:13 PM   #55
Adam, i'm really sorry, please take care of yourself.
You are more and more important to us as Adam the healthy.
We love you.
Take care and forget the scripts for a while.
Old July 8th, 2011, 06:48 AM   #56
Thanks! :)
Old July 8th, 2011, 02:37 PM   #57
Tried to post this over at Doom9, but I'm still in my probationary period.
The sample Sisvel files provided over at Doom9 are actually 1906x1074. Thus the AVISynth code to build a side-by-side (left first) is:
Code:
sisvel = FFmpegSource2("07-07_15-06-23_3D Tile Format_-01_new.ts", width=1906, height=1074)
sisvel = BicubicResize(sisvel, 1920, 1080)
sisvelLeft = Crop(sisvel, 0, 0, -640, -360)
sisvelR1 = Crop(sisvel, 1280, 0, -0, -360)
sisvelR2 = Crop(sisvel, 0, 720, -1280, -0)
sisvelR3 = Crop(sisvel, 640, 720, -640, -0)
sisvelRight = StackHorizontal(sisvelR1, StackVertical(sisvelR2, sisvelR3))
StackHorizontal(sisvelLeft, sisvelRight)
The conversion is problematic because of the sample files. The left image seems to be wider than 1280 and the R1 image is narrower than 640. The overall resolution and the sizes of L, R1, R2, and R3 are not what is indicated in the Sisvel spec.
You'll notice I use FFmpegSource2 which reads .ts files. As per the Sisvel spec, the playback is cropped to 1280x720, but by adding the width= and height= parameters to FFmpegSource2, we can grab the entire video. I then resize to 1920 by 1080 to keep everything standardized.
The way I determined the L, R1, R2, and R3 resolutions was to play the original TS file using Media Player Classic at exactly 100%, doing a screen grab, and then bringing the screen grab into Photoshop to use the Ruler tool. (Yes, I have a 1920x1080 monitor on my computer.)
Seref - could you pass this on to the Doom9 thread?
VRtifacts
Tony Asch is offline   Reply With Quote
Old July 9th, 2011, 01:30 PM   #58
Thanks Tony.
Nick has already passed your post to doom9.
BTW i reported your delayed membership to mods.
Best.
Old July 9th, 2011, 08:53 PM   #59
And Tony, i must admit DGNVTools is much better:
_ _ _ _ _
Old January 1st, 2013, 12:31 PM   #60
Hi Adam,
Even I can get very smooth stereoscopic videos with your tool or Avisynth's "StackHorizontal" or "StackVertical" options; I get shaky results with "Interleave" filter when I make frame-sequential videos. (Unfortunately, your tool does not have such a kind of option.)
Here, I explain the issue detailed:
Doom9's Forum - View Single Post - Any free MVC encoder yet?
Any feedback will be highly appreciated.
Thanks.
