Encoding MPG2 Files at DVinfo.net
Adobe Creative Suite
Old February 10th, 2008, 10:08 AM   #1
Encoding MPG2 Files
Need some help:
I have had Easy Media Creator 9 sense last spring 2007. It has operated flawlessly with one exception which I have been able to work-a-round. When I would try to encode MPG2 from Adobe PPRO 1.5, Easy Media Creator 9 would not recognize the file. I also have Adobe Premiere Elements 2. I would create an AVI file of my project in PPRO 1.5 then bring it into Elements 2 and encode it to MPG2 there and save it to mydvd project folder. When I launched Easy Media Creator 9 it would recognize the new MEPG2 file encoded with the Adobe Elements 2 encoder. Within the last two weeks I have purchased Adobe Premiere cs3 which I have the same problem. If I didn't have Adobe Elements 2 I would be Out-of-luck. It seems like I should be able to encode a MPG2 file from PPRO 1.5 or PPro cs3 that would work in Easy Media Creator 9.
Any ideas or suggestions to correct this problem would be appreciated. I have very limited understanding of the encoding process so go slow with me.
Thanks in advance.
Harry
Harry Lender is offline   Reply With Quote
Old February 10th, 2008, 12:37 PM   #2
With PP CS3 its easy.
Choose "Adobe Media Encoder" from the export menu options and there's loads of settings including MPG2 files.Incidentally, I though PP CS3 now comes bundled with Encore for DVD authoring which is musch better the myDVD...
Hope this helps
Graham Risdon is offline   Reply With Quote
Old February 10th, 2008, 01:54 PM   #3
Graham
Thanks for you reply. Yes I do plan on using Encore. It looks to be better. However I would still like to know why this problem occured Easy Media Creator 9. Thank again for your reply.
Harry
