Plug in to make colors POP at DVinfo.net
Adobe Creative Suite
Old May 1st, 2008, 10:51 AM   #1
Was wonder which plug in and settings would I use to make colors (of cars) really POP and stand out? Thanks.
www.speedandmotion.com
Duane Steiner is offline   Reply With Quote
Old May 1st, 2008, 01:04 PM   #2
I've always found the 3-way color-corrector effect to do the job nicely. However, if I'm in a hurry, the Fast Color Corrector effect does a good job as well.
As for third-party plugins, I used to work with a color-corrector that came bundled with a Canopus DV-REx RT capture card/breakout box setup, and I found that to do a marginally better job than what Premiere gives you.
Sometimes, all it takes is a little boost to saturation and contrast, but I've learned that great color correction requires a fine touch. Hope this helps.
Shawn McCalip is offline   Reply With Quote
Old May 3rd, 2008, 12:33 PM   #3
I personally don't own a copy - nor have I actually used it - but from what I've seen over at www.redgiantsoftware.com the Magic Bullet Looks product seems to be what you're looking for.
Devin Termini is offline   Reply
