Audio Problem with CS4 at DVinfo.net
Adobe Creative Suite
Old February 8th, 2009, 12:33 PM   #1
Hi there,
Can anyone help me with a problem I seem to be having with Premiere CS4.
When capturing from camera, video & audio are capturing fine, I can hear the audio being captured.
Drag it on to the timeline and theres no audio.
Can someone tell me if I have the settings setup wrong somewhere.
Capturing from camera into the Martox RT X2 breakout box via firewire.
Hope you can help.
Regards
Wayne
Wayne Greensill is offline   Reply With Quote
Old February 8th, 2009, 12:54 PM   #2
Did you give the audio time to conform? Did you hit Enter to render the audio?
Old February 8th, 2009, 12:59 PM   #3
Hi there,
Thanks for getting back to me.
I have only captured about 2 minutes of footage just to see if everything was ok, but no audio.
I will try rendering like you say and let you know.
Cheers
Wayne
Old February 8th, 2009, 01:12 PM   #4
Hi Adam,
Tried rendering like you said and still no audio.
If I play clip through windows media I have audio? Strange
Wayne
Old February 8th, 2009, 03:03 PM   #5
PP will automatically conform a clip's audio, but it might take some time depending upon the length of the clip. Something as short as yours should conform in a couple of seconds.
The question mark in your statement confuses me. Are you asking if the Windows media player will play any audio if it's there, the answer is yes.
You might want to double check that the project settings are the same as the clip. If they're not, problems may result.
Also look at the icon for the clip in the bin. If CS4 does it the same way as CS3, a clip with both video and audio will have an icon with a speaker over a strip of film. If the speaker's not there, PP only sees the video.
Old February 8th, 2009, 03:38 PM   #6
Hi Tripp,
Sorry for the confusion.
The footage I have captured through Premiere CS4 plays fine through Windows Media, with audio.
When I capture footage and drag it onto the timeline, in Premiere, there is no audio
The little speaker, like you say, is over the filmstrip and the audio on the timeline is not muted either.
I can hear the audio as it's being captured.
Wayne
Old February 8th, 2009, 06:48 PM   #7
When you play the timeline does any audio register on the VU meters? You can select their display in the "Windows" menu. If the meters register sound, then my guess is there's either a problem with the project settings or your Premier audio output setting are messed up. It shouldn't be a codec problem because WMP plays the audio without issue.
Old February 8th, 2009, 09:29 PM   #8
I'm with Tripp... the audio playback settings may need to be adjusted in Preferences. Premiere can be picky about what it outputs to.
Are you seeing a waveform or just a flat line in the audio track on the timeline?
Have you ever had correct audio playback from any clip with this install?
Old February 9th, 2009, 06:30 AM   #9
Thanks Adam & Tripp for your feedback.
There is no waveform showing on the timeline just a straight line. :o(
Helppppp!!!
I have just upgraded to CS4 from Pp2, I wish I hadn't now.
Old February 9th, 2009, 06:56 AM   #10
Is there audio if you play it from the program monitor without dragging it to the timeline? And the "take audio & video" toggle in the program monitor (not the project window) is correct, yes? Did you try using the Render & Replace command under the clip menu? And did you try messing around with the audio playback settings in Project settings or Preferences?
Here are some other threads from those having similar problems on a different forum:
Adobe Forums - Can't hear sound in Premiere CS3
Adobe Forums - No Audio Waveform
Maybe they'll help.
Old February 9th, 2009, 01:34 PM   #11
Maybe they'll help.
Hi Adam,
There is no audio when I play it in the program monitor either.
I can only hear the audio when it is being captured, the tab does say to take audio & video.
When I then come to edit, there is no sound, no waveform.
I have tried playing around with audio settings and still nothing.
I think I might just go for a reinstall.
Not sure what else to do :o(
Thanks Adam
Old February 9th, 2009, 01:39 PM   #12
Hi Adam,
Thanks Adam
There's another thing I did try and forgot to mention.
I added some footage that I captured with PP2 and that works fine.
So I assume it has to be something to do with the capturing.
Old February 9th, 2009, 01:59 PM   #13
Wayne, another thing you can try is to alter your clip audio properties. I'll often do this when I record two discrete mono channels onto my camera and do not want them inserted on the timeline as a stereo source.
You'll have to remove all instances of your test clip on any timeline, and then highlight the clip in question and the pull-down Clip>Audio Options>Source Channel Mappings.
Your timeline(s) will have to match the sources you pick (i.e., you'll need to insert mono tracks for mono clips, etc.).
Worth a shot,
Brian Brown
BrownCow Productions
Brian Brown is offline   Reply
