Still Photos + adobe premiere pro cs3 at DVinfo.net
Adobe Creative Suite
Old May 11th, 2010, 05:51 PM   #1
hi all
working on a [project currently in premiere. i added 9-10 still photos all ranging in resolution (some larger then 1920 x 1080 others smaller). i also have an animation i created in AE on top of the photos and video. however, occasionally the photos will just turn into a blank screen (black screen) and sometimes it will work. the video seems to cosistantly work, but not the photos. i cant render the video out either.
your help would be appreciated
Josh Chan is offline   Reply With Quote
Old May 11th, 2010, 05:56 PM   #2
one more quick thing to add, i've added motion to the photos. dont know if that matters
Old May 11th, 2010, 06:12 PM   #3
does the photo dpi affect anything?
thinking out loud haha
Old May 11th, 2010, 09:23 PM   #4
Premiere CS3 just hates photos, especially if they are larger than 1920 x 1080. And the more you add the more unstable it becomes. Also, it seems to tolerate PNGs better than JPGs.
So don't make them any larger than necessary and try to convert to PNGs if you can before importing.
Old May 12th, 2010, 07:24 AM   #5
Here are a few rules for photos:
- Longest side of photo should be less than 4,000 pixels
- Portrait photos always work, no problem
- Landscape photos should be exactly 16 X 9 prior to importing into PP hard drive folder
- Use .5625 and 1.777 formulas to insure landscape photos are 16 X 9
- I always use JPEG file format
Good Luck!!
Brian Barkley is offline   Reply With Quote
Old May 12th, 2010, 07:27 AM   #6
- Photo can be larger than 1080 X 1920 as long as you use the above forumlas
Good Luck!!
Old May 12th, 2010, 11:31 AM   #7
thanks so much guys! what we ended up doing, dont know if it actually worked or it was a matter of luck was we dropped the dpi 72 and it seemed a little more stable?... in any case we rendered the proj out.
thanks for all the advice and i'll keep it in mind for the next proj
Old May 12th, 2010, 04:33 PM   #8
Dpi has no relevance to video.
Dropping the dpi in PS just means you made the image smaller, you reduced the image size.
Black images usually means the images are too big.
Ann Bens is offline   Reply
