Quick Question: will CS5 work with my old Mac Pro from 2006? at DVinfo.net
Adobe Creative Suite
Old May 24th, 2010, 09:59 AM   #1
Dualcore 2.66gHz Mac Pro with the ATI 1900xt graphics card and 6GB of RAM.
I'd hate to spend $800 and realize it won't work completely. Thanks.
Newbie using Canon GL2 and Powerbook G4 1.25 gHz 512ram and a Mac Pro
Joe Calalang is offline   Reply With Quote
Old May 24th, 2010, 11:14 AM   #2
https://www.adobe.com/products/premiere/systemreqs/
Old May 24th, 2010, 10:28 PM   #3
yes, but you won't get hardware accelerated playback using the mercury PB engine....
Steve Oakley is offline   Reply With Quote
Old May 25th, 2010, 08:58 AM   #4
It works completely on 2006 iMac an even H264 is completely workable, but as Steve said, you won't get CUDA acceleration.
Jiri Fiala is offline   Reply With Quote
Old May 25th, 2010, 01:03 PM   #5
Can I get that by upgrading my video card? Sorry for the n00b questions.
Old May 25th, 2010, 01:40 PM   #6
I am not a Mac guy so I don't know, but I didn't think all the Macs from 2006 were 64 bit. I would trust the other opinions over mine. Just make sure you are running a 64 bit operating system.
Lloyd Coleman is offline   Reply With Quote
Old May 26th, 2010, 01:57 AM   #7
No, i am afraid that wont do the trick.
From the FAQ:
...For example, the NVIDIA Quadro FX 4800 for Mac requires MacPro 3,1 or MacPro 4,1 (2008 or 2009) or later. MacPro 1,1 and MacPro 2,1 are not compatible.
To see what Mac Pro you have, click on the Apple icon in the upper left corner of your Mac Pro screen and chose About This Mac. The model identifier should be MacPro 3,1 or MacPro 4,1 (2008 or 2009) or later.
/Roger
Roger Averdahl is offline   Reply With Quote
Old May 26th, 2010, 08:24 AM   #8
Originally Posted by Lloyd Coleman View Post
...I didn't think all the Macs from 2006 were 64 bit. I would trust the other opinions over mine. Just make sure you are running a 64 bit operating system.
It is likely that the OP's 2006 Mac Pro is still running a 32-bit operating system at present. Therefore, it cannot run CS5 at all unless the OP upgrades (updates) the OS to a 64-bit one. And CS5 requires MacOS 10.5.7 or higher just to even run at all. So, even if the 2006 Mac Pro is running a 64-bit OS, the OS that it is currently running is likely to be of an older version than the 10.5.7 required to run CS5 at all.
All of the Intel processors used in the Macs are 64-bit capable. Unfortunately, that 2006 Mac Pro is almost certainly of version 1.1, the very first released version of the Intel-powered line. Therefore, it cannot be upgraded to a video card that can use the GPU acceleration feature of MPE.
Randall Leong is offline   Reply
