Embedding alpha channel in exported annimation? at DVinfo.net
Adobe Creative Suite
Old July 7th, 2010, 09:00 AM   #1
Hi guys. Using CS5. I have Premiere Pro and After Effects, but I'd rather do as much as I can in Premiere as I know it much better.
Here's my situation: I've rendered an animation as a series of still images. The frames are 24 bit and do not have an embedded alpha channel. I did however render a separate sequence of images which is just the greyscale alpha images.
My question: Using Premiere (or failing that, After Effects) when I encode a video file of the animation, can I embed the alpha image sequence as the alpha channel of a 32 bit animation file? if so, how? I can't seem to figure it out.
Bob Drummond is offline   Reply With Quote
Old July 7th, 2010, 11:16 AM   #2
Rendering at Max Depth will give you the Alpha Channel.
Old July 9th, 2010, 02:32 PM   #3
Thanks, Ann. What I meant was how do I tell Premiere that the separate greyscale sequence IS the alpha channel.
