Editing 10bit material in 8 bit timeline. at DVinfo.net
Adobe Creative Suite
Old December 9th, 2011, 04:07 AM   #1
Hi
I record some of my material in AVCIntra 100 which is 10bit. When I put it into a 8 bit CS5 premiere timeline will I still be able to adjust the material as if it is 10 bit. Will i still have the 10 bit levels usable?
Bo Skelmose is offline   Reply With Quote
Old December 9th, 2011, 09:49 PM   #2
Equal Opportunity Offender
Re: Editing 10bit material in 8 bit timeline.
I believe that Premiere's internal processing is well beyond that, running at 32-bit internal calculations.
Just use a timeline that matches the resolution for the project and see how you go.
Andrew
Old December 10th, 2011, 04:29 AM   #3
And remember to click "render at maximum depth". Otherwise the rendering is limited to 8-bit.
Creative Impatience - The Solace of Simple Solutions. A few useful plugins for Adobe users, and my remarks on the tools and the craft in general.
Bart Walczak is offline   Reply With Quote
Old December 10th, 2011, 06:16 AM   #4
Not all effects are done in 32-bit. Those that are are clearly marked to the right of the effect's name in the effects panel. You also have a toggle button to show only 32-bit effects at the top of the panel.
Jon Shohet is offline   Reply With Quote
Old December 10th, 2011, 07:52 PM   #5
Additionally, you don't need to click the "maximum depth" button if you have a supported NVIDIA graphics card that is being used by the mercury engine.
See Adobe CS5.5 Max Render Quality & NVIDIA GPU acceleration for in-depth details.
Andrew
Old December 12th, 2011, 02:14 AM   #6
Andrew, I think you're confusing the "Maximum Bit Depth" setting with the "Maximum Render Quality" setting. The former still needs to be selected in the sequence setting dialogue to support high bit depth processing of effects as far as I know.
Old December 12th, 2011, 02:31 AM   #7
Ahh, I think you are right. Maximum render quality is what I was thinking of.
Mind you, I think Premiere would be calculating in 32bit space as much as is allowed by the bit depth of the plugin. We do have an Adobe rep around here somewhere. He might be the one to answer that one conclusively.
Andrew
