best HD export settings for CS5, broadcast delivery at DVinfo.net
Adobe Creative Suite
Old January 14th, 2012, 12:27 AM   #1
To deliver a HD show, 1080 30p, what would be the best export options from native premiere? Its going to be converted to HDCAM or HDCAM SR, was wondering what settings/codec you guys would recommend for the least (or none at all) compression.. Thanks
Spike Spiegel is offline   Reply With Quote
Old January 14th, 2012, 01:50 AM   #2
Re: best HD export settings for CS5, broadcast delivery
Lagarith, UT or uncompressed.
Old January 14th, 2012, 05:14 AM   #3
Thanks, will check out Lagarith. As for bit rate, any specific details? Are there any hardware rendering options? I"m guessing Lagarith is an option if one were to not wanting to stick with adobe's native software encoder?
Old January 14th, 2012, 05:30 AM   #4
ps, what are some solid dedicated encoding softwares that are out there that will work well with cs5/64 bit environment
Old January 14th, 2012, 07:11 AM   #5
No bit rate settings, no hardware required, simply use AME and choose Lagarith, UT or uncompressed and export.
Old January 17th, 2012, 01:52 AM   #6
Was able to encode using lagrith but windows couldnt play back the file, i' mnot sure if the post house will be able to play back the lagarith encoded file when they out put to HDCAM..
What dedicated encoders are people using here? Also, does any of Premiere's native settings work well for HDCAM delivery?
Old January 17th, 2012, 05:14 PM   #7
Why not ask the post house what they prefer?
Roger Keay is offline   Reply
