vegas to ppro?
can anyone point me to a good learning / technical resource for a competent editor moving from vegas to ppro?
most of the stuff i've read, watched is hopeless in as much as it's usually long, waffling and not aimed at pro editors making the switch.... tia |
Re: vegas to ppro?
Re: vegas to ppro?
Just dive in at the deep end. Set up a project, import some footage and it will all seem reasonably intuitive. I did this, having prior experience of Liquid and Avid and it was reasonably plain sailing. You are right to ignore the general tutorials. If you get stuck on a particular area, e.g. Ultra Key, there are great tutorials on Adobe TV: Adobe TV. Good luck
Re: vegas to ppro?
I must be incredibly dense, but I've been trying to move from Vegas to Premiere for at least five years! Eventually, I'll get frustrated and close to deadline, and just go back to Vegas.
What makes this even more pathetic is that I'm very proficient with After Effects! I just don't know why I can't get the hang of Premiere. |
Re: vegas to ppro?
Re: vegas to ppro?
If somehow my install of Vegas was deleted and I had no choice but to do it in Premiere, I guess I'd just knuckle down and do it. |
Re: vegas to ppro?
Hi Chris,
I had to go through that my self. Adobe TV has great tutorials and also Lynda.com. If you have any question you can post it here and we will try to help you. |
Re: vegas to ppro?
A really great place to start is by learning the keyboard shortcuts. Do whatever you ave to do to get used to them - read them before bed, print them and stick it to the back of the bathroom wall, mark your keyboard with permanant makers, etc.
If you really dig into the shortcuts you'll find yourself breaking/relearning habits you might've developed in Vegas. I found these habits to be what was slowing me down when I made the switch from Vegas to Premiere about three years ago. Once I got the hang of the shortcuts, I spent less time struggling with the different interface and button layout, because I did more things using just the keyboard. Over time, the interface and menu layout became equally as natural as Vegas had been previously. |
Re: vegas to ppro?
Easier still, just re-define the shortcut keys so they are the same as Final Cut, Vegas or other NLE
Re: vegas to ppro?
I use Shuttle ProV2 and have Edius, Vegas and CS5.5 set so they all work the same with the controller.
Ron Evans |
Re: vegas to ppro?
Re: vegas to ppro?
but with CS6, if PP will handle H264 and raw files as easy as Photoshop CS6 does , I will probably switch back to Adobe. |
Re: vegas to ppro?
I guess we all have our favourite applications, If Vegas works for you then why change. I have always used Premiere and can't see what the problem is. The only hiccups I have encountered is when I used the Matrox R100 and RTX2 cards, but since using the nVidia cards with Cuda and Mercury Playback Engine, I have taken the Matrox cards out altogether.
I look forward to using CS6 and other applications in the Adobe Production suite, it sounds like Adobe is going to take the crown away from Final Cut, just as they did with InDesign against Quark. Could be Interesting times ahead. |
| All times are GMT -6. The time now is 08:22 AM. |
