Exporting video for Archiving, premiere pro at DVinfo.net
Adobe Creative Suite
Old May 30th, 2012, 01:33 AM   #1
I have a completed video and want to export it for archiving, for the future if I need to import again to make DVDs or online compatible videos. Is exporting with quick-time animation 32bit my best bet? or would something else be better?
video is 1080p
Dave Morgan is offline   Reply With Quote
Old May 30th, 2012, 06:39 AM   #2
Re: Exporting video for Archiving, premiere pro
In most cases it's best to archive a video in it's original acquisition format, frame rate & size. Minimizes transcoding, upresing/downresing issues.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old May 30th, 2012, 02:44 PM   #3
I respectfully disagree. Any Interframe codec like MPEG-2 (HDV/XDCAM) or AVCHD (h.264) will always be recompressed by Premiere on output, introducing yet another generation loss on top of the compression already applied by the camera.
Animation 32-bit might be a bit of an overkill. If your video is not transparent, then 24-bit will be enough, since additional 8-bit encoding alpha channel would be wasted anyway.
You can also try the Lagarith codec (it's free) for the highest fidelity, or download Avid's free DNxHD and use one of the higher bitrates provided there. The filesize will be a bit more manageable, and the quality loss almost undetectable, especially if it is your master.
Creative Impatience - The Solace of Simple Solutions. A few useful plugins for Adobe users, and my remarks on the tools and the craft in general.
Bart Walczak is offline   Reply With Quote
Old May 30th, 2012, 06:37 PM   #4
'AVCHD (h.264) will always be recompressed by Premiere on output'
doesn't pro smart render?
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old May 31st, 2012, 06:24 AM   #5
No. Premiere Pro always unpacks and recompresses AVCHD no matter what.
Randall Leong is offline   Reply With Quote
Old May 31st, 2012, 06:43 AM   #6
Usually true. However, with today's common highly-compressed formats, Premiere Pro will always transcode such material upon import no matter what. This is partly because Premiere Pro still lacks true smart rendering support for the newer codecs such as AVCHD (yes, even in CS6 6.0.1).
Old May 31st, 2012, 05:22 PM   #7
how do I use the Lagarith codec, I downloaded it, but if I export in premiere is it a setting in quicktime, or should it show up as its own thing?
Old May 31st, 2012, 05:43 PM   #8
It is a custom setting within the AVI encoder in Premiere (when you select AVI, the default is usually DV or DV widescreen; therefore, Lagarith has to be selected manually in the codec drop-down list).
