Compact Flash import problem - Page 2 at DVinfo.net
Adobe Creative Suite
Old July 7th, 2012, 11:40 AM   #16
Re: Compact Flash import problem
Very interesting. Looks like we've been barking up the wrong tree.
Old July 9th, 2012, 08:45 PM   #17
Apparently there is a problem with Premiere Pro CS6 and Adobe is aware:
Adobe Forums: Premiere Pro/Prelude CS6 not working with AVCHD from Canon HF G10
The issue only arises when you're recording a continuous shot that is automatically broken up into those 4GB files. Those "wrapped" files won't import into CS6, even though there was no problem in earlier versions of PP. Hopefully there will soon be a fix.
Paul
Paul Budline is offline   Reply With Quote
Old April 13th, 2013, 08:30 AM   #18
I just started with compact flash yesterday and have run into this exact problem with CS6. Is there a fix for this problem?
As a test, I went back to a computer that had CS3 installed, the clips work PERFECTLY in CS3! But not in CS6. I'm hoping there's a fix.
Tracy Painter is offline   Reply
