Audio Question in CS6 Premiere Pro at DVinfo.net
Adobe Creative Suite
Old August 15th, 2012, 01:04 AM   #1
Can some one tell me is there a way to set this as the default, as it seems silly to have to do this to every single clip, i have 30 clips, interviews, i need to change and it seem to take so much time, going into each one at a time changing them . I have reordered using 2 mics, (Lapel on Person 1, and Other Lapel on 2nd Person. I need to dip one of the lines as the other is talking. see screen shots.
Rob.
www.rpbproductions.com
robert@rpbproductions.com
HD101/G5 Mac/4gig Ram/1TB HDD/30" Cinema Display/FCP.
Robert Bale is offline   Reply With Quote
Old August 15th, 2012, 01:07 AM   #2
Re: Audio Question in CS6 Premiere Pro
Screen Shots
Audio Question in CS6 Premiere Pro-1.png   Audio Question in CS6 Premiere Pro-2.png
Rob.
Old August 15th, 2012, 04:20 AM   #3
You don't have to do it clip by clip, just select all of the clips in the project bin and then right click and modify audio ch. to mono. You only need two tracks, it doesn't make sense to make two "stereo" tracks, each with identical channels.
Zoran Vincic is offline   Reply With Quote
Old August 15th, 2012, 04:51 PM   #4
Hi, Thanks for the help, that makes life so much easier. Cheers. !!
Rob.
