CUDA not working in PP cs6 at DVinfo.net
Adobe Creative Suite
Old December 18th, 2017, 01:54 AM   #1
Hi, i have a problem with my Nvidia card, when i select to render with CUDA instead of software mode i get a black screen in all video. Clips play and hear audio but no video. Anyone know a work around?
Thanks, Cheers
Gary Smith.
Gary A. Smith is offline   Reply With Quote
Old December 18th, 2017, 07:52 AM   #2
Re: CUDA not working in PP cs6
one thing to check is to see if your card is certified for use with Premiere Pro.
If not check out this site;
https://www.studio1productions.com/A...remiereCS5.htm
It has a huge amount of info regarding nvidea cards and Premiere Pro.
cheers
R
http://www.robertcantwell.com
Old December 18th, 2017, 09:55 AM   #3
Please share WHICH card you have, as that will help sort things. Also, try updating the nVidia graphics driver, available here - https://www.geforce.com/drivers
Jeff Pulera
Safe Harbor Computers
Old December 18th, 2017, 12:05 PM   #4
If you are using an Intel cpu with on-board graphics, it may be that the intel graphics are selected as the default for Premiere. If so, open the nViida setup and select "high quality NVidia" as the default for your various Adobe apps. Also, check if your "cuda supported cards.txt" file found in your Premiere app folder includes your particular NVidia card, and if not, add it with a text editor.
BTW. Photoshop runs fine on intel graphics and will take forever (at least on my system) to find the nVidia card and access it, so I run my photoshop on intel, and PPRo and After Effects on the nVidia card.
Old December 18th, 2017, 01:44 PM   #5
Sorry, pays not to post when in a hurry. 1. Card is GeForce GT640, was not listed but i added it a few years ago. 2. Driver date 31\7\17 or for Amarakins - 7\31\17.
3. Card has been working for several years with no issue. It feeds a 32" tv and a 24" monitor. Onboard grafix feeds another 32" tv. I have a feeling it has something to do with drivers. i found a util that totally removes the drivers so will try that slowly add older drivers till it breaks again. LOTS of others in the same boat. They get their answer "use software rendering", what a waste of an answer. it DOES work with 720 but 1080 and higher, black screen.
Thanks, Cheers
Gary Smith.
Old December 18th, 2017, 09:43 PM   #6
7/31/17 is pretty ancient in the NVIDIA driver world. I believe the current version is 12/7/17.
Luke Miller is offline   Reply With Quote
Old December 18th, 2017, 10:51 PM   #7
Well i took it back to a 2015 driver and it's working fine. i DID update drivers two separate times but still didn't fix it.
Thanks, Cheers
Gary Smith.
Old December 19th, 2017, 05:51 AM   #8
Sometimes PP doesn't recognize CUDA on my system, either. Almost always a restart of the program will fix it. CUDA makes such a huge difference working with 4K on my machine!
Phil Murray is offline   Reply With Quote
Old December 19th, 2017, 02:27 PM   #9
CUDA of GeForce GT640 is slow, may be using CPU only is the better choose.
Juris Lielpeteris is offline   Reply
