Drop Frame Problem? at DVinfo.net
Adobe Creative Suite
Old February 11th, 2006, 03:58 PM   #1
Drop Frame Problem?
Does anyone have drop frame problem when importing video?? I've just bought a VX2100 and had a good long day shoot. When i began importing the footage to Premiere, I've got alot of Drop-Frame Problem. The setting was set on non-drop frame and the video looks fine. Does anyone have any idea how i can prevent this? or what I'm doing wrong?
Kawai Sin
www.rollingedit.com
Kawai Sin is offline   Reply With Quote
Old February 13th, 2006, 06:44 AM   #2
I try to give some ideas
Have a good day, dear colleague!
I had a same problem.
If I understood correctly, You have a dropes into a project, not in a Capturing time. Does it correct?
So I can recomend your, dear Kawai, to start a absolutly new project or to reinslall your Premier...
Also, try to check your imported files, their format, parameters, etc.
Premier don't likes some formates.
Best regards.
Normund Mezhetsky is offline   Reply With Quote
Old February 17th, 2006, 11:20 PM   #3
Hey Kawai Sin!
Have you sorted your problem of dropped frames yet?
Jan Krenc is offline   Reply With Quote
Old February 19th, 2006, 07:26 AM   #4
See this thread.
www.dvinfo.net/conf/showthread.php?t=61021
James Emory is offline   Reply With Quote
Old February 19th, 2006, 07:47 PM   #5
Hmm.. yea, it think that helped, I'm trying to capture video on my laptop that has 5200 RPM and when the sound gets really high it sort of drops. I'm guessing more data is pass through at that point. And sometimes after that it just continues the drop. When i try it on a higher RPM drive it turned out much better.
Thank you
Kawai Sin
www.rollingedit.com
