After Fx:best Video Compression? at DVinfo.net
Adobe Creative Suite
Old June 8th, 2006, 01:27 AM   #1
Hi, I'm working on a project an I need to export a combination of many layers from After Effects 7. Since I can't export uncompressed video (1 min=almost 2 gig) because the project is huge, I'd like to know which would be the best compression option to export. Once exported, these files will still have to go to Premiere Pro 2.0, so they need to be compatible.
I have the following options:
- Microsoft DV
- Cinepak
- Indeo video 5.10
- Intel indeo video 4.5
- Intel indeo(R) video R3.2
- DVX 6.1
- DVX 6.1 YV12
- Xvid mpeg4
- Microsoft video 1
- Microsoft RLE
- Intel 4:2:0 video V2.50
Rafael Lopes is offline   Reply With Quote
Old June 8th, 2006, 09:54 AM   #2
I'd recommend the Microsoft DV format, as it's only about ~13GB per hour of video.
Matt DeJonge is offline   Reply With Quote
Old June 8th, 2006, 10:31 AM   #3
I would install huffYUV or MSU Lossless codec (be sure to uncheck Enable delta-frames and check Always suggest RGB for output).
Emre Safak is offline   Reply With Quote
Old June 8th, 2006, 10:48 AM   #4
After reading about the MSU Lossless codec I was amazed. It sounds great. Did you try it?
Old June 8th, 2006, 11:11 AM   #5
I use it to export footage between Vegas and After Effects, because Microsoft and Sony have incompatible DV codecs.
