Premiere crashes at DVinfo.net
Adobe Creative Suite
Old November 29th, 2006, 01:01 PM   #1
Premiere crashes
When I try to capture in PPro 2, the program crashes. In the task manager I see that when I open the capture window, premiere goes to or near 100% then it goes down to 0. Then, explorer.exe goes to 100%. I’m not sure why?
Any help is greatly appreciated
Joe Riggs is offline   Reply With Quote
Old November 29th, 2006, 05:58 PM   #2
Not enough details to answer. What source are you capturing from, and what are the specs of your computer?
Old November 30th, 2006, 07:23 AM   #3
HDV downconvert to DV on a P4 2.0 ghz 512 ram. These specs are not enough to deal with HDV but it should be enough for DV. I just want to make sure it's the specs of the CPU and not something else.
Old November 30th, 2006, 07:54 AM   #4
You have to down convert in camera, so you will be capturing a DV stream. Also your memory is very low and possibly your disk configuration is also sub optimal. Details please.
Old November 30th, 2006, 08:53 AM   #5
Try capturing your HDV footage with HDV Split (free utility) then import that into PPRO 2.0. I have a similar laptop, Sony Vaio P4 @ 2.4 GHz processor with only 512 RAM and it works without crashes - don't ask me about the speed though... I'm just experimenting wiht high def at this point.
Your PPRO probably crashes because it runs out of RAM - can't keep up with the work load, so "it throws arms up". With HDV Split you are only using a small part of your computing capabilities, being a small application... PPRO by itself eats up almost all of that RAM even idling...
You definitely need more RAM... a lot more RAM...
Ervin Farkas
www.AtlantaLegalVideo.com
Old December 2nd, 2006, 08:56 AM   #6
Okay, now the same thing is happening when I try to capture from my DV camera. I know my specs are low but I have never had a problem capturing DV footage with my PC.
Could it be a virus or should I do a fresh install of premiere?
Old December 2nd, 2006, 10:05 AM   #7
I repeat, details please on your setup and configuration.
Old December 2nd, 2006, 03:18 PM   #8
Harm Millaard see post #3 (running Win XP home ed.)
I think I figured out the problem, when my computer recognizes the camera, Premiere doesn’t respond, when I turn the camera off, premiere responds. This is really strange.
Anyone know how to fix this?
Old December 2nd, 2006, 05:11 PM   #9
Doesn't PPro 2.0 require Windows XP Proffessional?
Bart Walczak is offline   Reply With Quote
Old December 5th, 2006, 12:52 PM   #10
No it works on Home ed.The problem turned out to be my firewire cable.
