DV Rack & Live Multicam switching at DVinfo.net
Adobe Creative Suite
Old December 8th, 2006, 02:08 PM   #1
I'm not sure if this is even possible, but here's my idea:
Install DVRack on my laptop (17" screen).
Hook up 3 GL1 cams to some sort of firewire switcher/spliter (does this exist?)
Hook the switcher/splitter to the laptop via firewire
Running DVRack would I be able to monitor all 3 feeds and live-switch the recording? Having it record straight into my laptop hard drive.
Thank you for any help on this. I'm trying to figure out if it is possible to use my laptop+DVRack (or another software) to mimic the video-switching & monitoring capability of the Datavideo SE-800DV
Lisa Shofner is offline   Reply With Quote
Old December 8th, 2006, 03:39 PM   #2
Not sure mechanical switching is fast enough
I'm surprised SM hasn't figured out how to turn DV-Rack into a live switcher.
My thought is that you could have mutliple Firewire cards in a computer (1 per camera) and electronically switch sources.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old December 8th, 2006, 06:10 PM   #3
NewTek Tricaster.
Keith Nealy
Productions
Keith Nealy is offline   Reply With Quote
Old December 8th, 2006, 06:14 PM   #4
With your laptop idea, how would you monitor all three sources?
Also your firewire switch would have to perform vertical interval switches otherwise you would get a glitch -picture roll on every switch.
It's more complicated than you may be thinking.
Keith
Keith Nealy
Productions
Old December 8th, 2006, 06:39 PM   #5
The Tricaster looks interesting, I'm checking that one out. Thank you for that.
With the laptop idea, just an idea. I'm almost certain it won't work simply because if it did then there would be no reason for someone to use specific hardware instead of a less expensive laptop setup (IMHO).
I was thinking that DVRack would allow me to view the multiple cameras. However, I asked here because I haven't actually used the system myself and thought someone would be able to enlighten me on if that is even possible. It's sounding like it is not possible to configure a system as i was originally hoping I could.
Old January 14th, 2007, 09:31 PM   #6
I use the Newtek Video toaster which is the larger brother of the Tricaster and I can tell you this is the best way to go for sure. There is special hardware which makes it all possible. A computer by itself would have a hard time doing all the live switching aspects involved so the laptop idea (presently) wouldn't work very well. The only other thing you could do is get a used switcher off of ebay and use that. If the switcher has firewire output, you could record the output on your laptop but that's about the extent of what a laptop (with only software) is able to do at the moment...
Richard
http://www.coollights.biz
Richard Andrewski is offline   Reply With Quote
Old January 28th, 2007, 03:14 PM   #7
Remote CCU
There are of course, distance limitations with Firewire that might be a bit of a hindrance for a multicam setup. For Firewire400 I think it's only 15feet.
I was kind of thinking of something similar with the Canon Console software but to be able to control the camera functions remotely, like a CCU (camera control unit) on studio cameras.
Russ
Russ Speiser is offline   Reply With Quote
Old March 15th, 2007, 08:15 PM   #8
re
you could try 3 laptops and remote desktop... that is if you happed to have 3 laptops lying about.
R. Phil Johnston is offline   Reply With Quote
Old December 6th, 2007, 06:44 AM   #9
On HDVRack you need to goto the menu and change between the camera's.
Before Serious Magic was bought by Adobe I requested to be able to assign hot-keys. To be able to switch easily between multiple inputs...
Marc Colemont is offline   Reply With Quote
Old December 13th, 2007, 08:38 PM   #10
Russ,
I do live camera work with 4 XL-H1s and, so far, I have not purchased Console to use as CCUs, but I plan to this year. Although it's not cheap, you can get fiber optic conversion hardware to convert firewire to optics and then back again. The optic cable can run up to 1600 feet!
Here is an example of the hardware available:
http://www.gefen.com/kvm/product.jsp?prod_id=2808
One big downside to this is 4-pin firewire is a horrible connection - I mean the actual physical connectors. It's very fragile and falls out or bends easily. I wish there were a better option for connecting to the camera.
-Vence
Sony PMW-EX1R, Canon XL H1, XHG1, Panasonic GH2, Mac Pro 3.2 Quad running FCPS 3, FCPX, & Adobe Creative Cloud CC www.creativejuicesvideo.com
Vence Vida is offline   Reply With Quote
Old February 10th, 2008, 07:49 PM   #11
Hmmmm.....why not try Vera Software's Wirecast? I've used it before for multiple camera live switching for a live webcast. I don't remember for sure, but I think you can pick the codec and size that you save your file as if you do an 'archive'. As mentioned, one drawback is the silly 4 pin connectors on camera's, it sucks that they will fall out so easy.
Gabe Strong is offline   Reply With Quote
Old February 14th, 2008, 08:55 PM   #12
Gabe - how does Vara Wirecast work with multiple DV cameras, or does it? I'm looking at getting a Tricaster or renting one, but if it would do even just two DV cameras I might be able to save a lot of money going that way. Would it work on a MacBook Pro?
Philip Gioja is offline   Reply With Quote
Old March 2nd, 2008, 03:40 AM   #13
Phillip,
Sorry it's taken me awhile to get back to you.
Yes, Wirecast can handle two DV cameras. I have used 3 DV cameras before on my old 1.5ghz G4 powerbook. There are some things you can do to make it work better, but you should have no problems with only 2 DV cameras....and I was doing this on my old powerbook so a macbook pro should have no problems.
I just finished a 7 month contract broadcasting live meetings for the state and I used the laptop/software route with no problem. I also just finished a two day broadcast this past week using Sony's Anycast (which is similar to the Tricaster stuff). So I am pretty familiar with the pluses and minuses to them all. One good thing about wirecast is that it has everything needed for a small livecast (even a built in server to send your broadcast live to a limited number of people).
Anyways, that's about all I can say on this. I DO have a consulting portion of my business, helping people with live webcasts so I don't want to give away ALL my secrets on a public internet forum!
Gabe Strong
www.gforcevideo.com
