Export woes.. at DVinfo.net
Adobe Creative Suite
Old December 14th, 2006, 02:45 AM   #1
Export woes..
Greetings, i cannot for the life of me export my movie. i have tried almost every media type and it keeps stopping 30% in. I am using PP2 with Cineform Prospect HD. I imported the clips via Cineform from my JVC HD 100. The movie edited fine and even let me make an mpeg2 for a dvd. I have been on the phone with tech support to no avail. I just used the Project Manager and made a copy of the project with media. i tried rendering that with no luck. The movie is 95 min.
Any help will be most appreciated.
David Basulto is offline   Reply With Quote
Old December 14th, 2006, 01:31 PM   #2
anyone have some ideas?
Old December 14th, 2006, 10:53 PM   #3
I assume the drive it's saving to is not full, and isn't FAT32 (i.e., 2Gig limit)?
Old December 14th, 2006, 11:23 PM   #4
no theres plenty of room on the drive.
Old December 16th, 2006, 02:07 AM   #5
What format do you want to export your timeline in?
Jon Jaschob is offline   Reply With Quote
Old December 16th, 2006, 01:14 PM   #6
Either QT or DV AVI
Old December 16th, 2006, 01:55 PM   #7
I had problems using PPro2, Aspect HD, and the JVC HD100 24fps timeline.
These problems happened regularly.
Timeline would loose it's rendered FX files and project could not be saved. I had to do a Save As to rescue my film.
A section of the timeline would not render/export with nothing unusual in the spot it errors out.
A section of the timeline would not render/export using Magic Bullet. But other sections with MB had no problems.
Program Crashes requiring a recovery process.
I found that I had to identify the error area/s and try to render that clip, or clips out as a separate file, then import that file into the timeline.
Also, if it errors out in the same place, try re-importing that clip either into PPRo2 or again off the tape.
Most of the time I was able to fix the problems, but it took a lot of time, sometimes weeks on end with support. (keep after them, this is new technology and we are the beta testers, I kid you not!)
But, I was able to work through all the problems and export my film into m2T, Qt, FLV, and widescreen DV avi.
Jon
