exporting to Quicktime at DVinfo.net
Adobe Creative Suite
Old February 10th, 2007, 12:45 PM   #1
I need to export my HDV project into quicktime format for internet, so it could be downloaded, 1min=10mb is ok, but not more.
How can i do that?
Should i use adobe media encoder? If yes, which settings should i use?
thanks a lot!
Andzei Matsukevits is offline   Reply With Quote
Old February 10th, 2007, 05:07 PM   #2
Do you need to post a huge HDV frame, or something more reasonable like a 400X224 frame?
The smaller frame will allow you to use a 1024K data rate in the Adobe Media Encoder and have the file come out at 8MB for one minute.
If you are going to export to Quicktime on a regular basis, I recomend that you purchase Sorenson Squeeze to get a much higher quality.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old February 10th, 2007, 07:47 PM   #3
Kino-Eye
For QuickTime files, the highest quality Codec available is H.264 (a.k.a. MPEG-4 Part 10) codec along with AAC for the audio. I've posted the settings I like to use when exporting QuickTime QVGA (320x240) H.264 movies in this article: Secret recipe for amazing image quality video downloads. Have fun!
Another option to consider for web video that is more universal than QuickTime is FLV (Flash 8) files, however, if you want to be Video iPod compatible, stick with QuickTime.
Both QuickTime/H.264 and Flash 8 movies require quite a bit of processing power for playback (decompression) so older machines will have trouble playing 30fps movies. That's one reason why I make most movies 15fps, in order to optimize for spatial quality over temportal quality.
David Tames { blog: http://Kino-Eye.com twitter: @cinemakinoeye }
David Tamés is offline   Reply
