fliipping footage 180 degrees? at DVinfo.net
Adobe Creative Suite
Old July 6th, 2007, 07:49 PM   #1
I have a section of film that was shot sideways. Now I doubt it can be done, but is there a trick in premiere express so that this two minute section could be flipped 180 degrees?
Mark Yang is offline   Reply With Quote
Old July 6th, 2007, 09:31 PM   #2
"Sideways"? You mean that the camera was turned on its side, so the image is rotated NINETY DEGREES? If you flip it 180 degrees, it will still be sideways, just facing the other way.
Richard Alvarez is offline   Reply With Quote
Old July 6th, 2007, 10:38 PM   #3
Yes, that is correct, it would be ninety degrees, not one hundred and eighty.
I suspect digital frames are not square, so it would be impossible to do. But with the wonders of digital software?
Old July 6th, 2007, 10:54 PM   #4
Images: 1
You can flip it 90, but assuming it's widescreen the sides will be black bars. You can enlarge it, but this clips a lot of the image and degrades image quality. I shot part of a music video of mine sideways and ended up using none of that footage. I think it's useless tilting the camera like that.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old July 7th, 2007, 08:36 AM   #5
I had heard about shooting sideways to get 720HD and did a test on it. I just captured the footage in an SD project and imported it into a 720p project, rotated it 90 degrees and it fit perfectly. But now that I have the XH-A1 I don't need to do that any more.
Here's a link to the video click on Play how we made it to view a walk through video.
http://www.kraentertainment.com/newhightechtest.html
Kevin | www.kraentertainment.com
A picture is worth 1,000 words | A 2 hour film at 24fps is worth 172,800,000 words
Kevin Amundson is offline   Reply
