Sennheiser ME66/K6 TO SD 442 to XL2
Greetings:
I am having an issue with distortion. Current setup: Sennheiser ME66/K6 phantom powered at 12 volts from sound devices 442 balanced xlr into sd 442 sd 442 input for input #1 set to phantom, mic input, 48 volts, unity 0 , gain 22, master at 0, I have set tone for the xl2 at 2db, sd meter shows 0. Audio input on xl2 is set at ch1 and ch2 manual when I sent a tone to the camera I set the xl2 audio meter to 2db with channel one knob adjusting the audio levels. When I listen to the headphone return on "a" which is the headphone output from the xl2 it sounds distorted but when I listen to the headphone strait from the sd 442 it sounds very clear. Am I doing something wrong ? Any pointers would be greatly appreciated. Thanks in advance for any help on this setup. no default settings have been changed on my 442. Sincerely , Ty Chu |
Make sure that the XL2 is set to the appropriate input level -- "Line Level". Then take a listen. |
Thanks for the heads up Jim
All is well now, Thanks Jim
Cheers, Ty |
Cheers, Ty |
| All times are GMT -6. The time now is 12:35 PM. |
