Looking for a Certain Audio Effect at DVinfo.net
All Things Audio
Old August 12th, 2007, 02:04 PM   #1
Does anyone know of a way to make a sound effect of someone breathing sound like your own breath does when you cover your ears?
I'm using FCP and wondering if there's a certain setting or filter I can use. Thanks.
John Jaquish is offline   Reply With Quote
Old August 12th, 2007, 03:15 PM   #2
it is the noise of air passing into a tube, so just do the same.
choose carton tube (even wet) because plastic or metal will have different frequency behavior.
Old August 13th, 2007, 01:51 AM   #3
are you looking for just the breathing, or also the "rumble" noise you get when you cover your ears?
Mike Peter Reed is offline   Reply With Quote
Old August 13th, 2007, 02:57 AM   #4
It's mostly lower frequency stuff (muffled sound). Try a parametric EQ with the highest band (shelf) set to cut, and drop it to maybe 1,000Hz to start with. This will give you only mid-bass and bass. You can slide it back n forth to fine tune it. Also try without 'cut' mode, and just drop the higher frequencies by 20 dB or so, depending on how much you need intelligibility in the sound.
Eric
Eric Shepherd is offline   Reply With Quote
Old August 13th, 2007, 04:18 PM   #5
Great. Thanks for the advice.
Old August 13th, 2007, 04:19 PM   #6
The rumble, too.
