Boom Pole? at DVinfo.net
All Things Audio
Old September 5th, 2007, 11:23 AM   #1
Boom Pole?
What would you recommend for a cheap boom pole? It'll be holding an AT-55.
Brian Boyko is offline   Reply With Quote
Old September 5th, 2007, 11:47 AM   #2
A carbon-fiber painting extension tube is cheap. PVC is cheaper still.
Emre Safak is offline   Reply With Quote
Old September 7th, 2007, 04:56 PM   #3
Cheap usually means heavy. If you're not the one holding the boom, well, someone has to hold it.
Regards,
Ty Ford
Old September 7th, 2007, 05:21 PM   #4
PVC has a lot of flex (aka bounce). The painter poles, when I checked, were way to heavy and too long even collapsed to fit in a car. I ended up going with a lighbulb changing pole. It is light to hold and colapses down to something around 6' with a max of 11'. There is some slight flex when it is fully extended, but not a lot.
I use it with an AT897 (11") with foam wind shield in a shockmount and with an AT835b (14").
Lisa Shofner is offline   Reply With Quote
Old September 7th, 2007, 05:37 PM   #5
A bamboo fishing pole would be light and cheap. And it could be called the ....
BAMBOOM
Jim Michael is offline   Reply
