Advice on microphone shockmounts for boom pole at DVinfo.net
All Things Audio
Old December 21st, 2007, 10:14 AM   #1
Just picked up an Audio Technica AT4073a to use for a boom mic on an upcoming production. The vendor recommended a AU8415 shockmount for this unit. I have tried it on the end of the boom pole and the bands seems a little loose. The mic is fairly secure and probably would not fall out but it seems as though the tension from the mic cable (very little of it but there is some) causes the mic to slip and the bands to give a little. The mic can be slightly moved and can touch the sides of the shockmount when this happens. The vendor also mentioned a "spring" mount that AT makes. Can anyone advise on this? I have an inexpensive boom pole so the cable has to run on the outside. Any advice on how to secure it, yet still have flexibility in telescoping up and down when needed?
Thanks in advance.
Marty Hudzik is offline   Reply With Quote
Old December 21st, 2007, 01:43 PM   #2
Images: 32
I also think the AT4073 feels a little loose in the standard AT8415 shockmount bands. Switch them out with something like the K-Tek K-SUS Microphone Suspenders.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old December 21st, 2007, 02:37 PM   #3
The K-Tek bands work very nicely. One tip from Mr. Klemme himself: if you use the K-Tek bands on the AT shockmount, drill (with a small bit, just a bit larger than the slit) in the corners of the slits holding the bands to round out the edge of the mount against the K-Tek band.
One obvious note: are you crossing two of the bands on each end of the mount? That is, you don't just push the mic through, but at each end you cross two bands and push the mic through. I have the 4073a and AT shockmount and haven't had a problem.
Top secure the cord to the cable try something like these:
http://www.bhphotovideo.com/c/produc...ap_1_x_9_.html
As the explanation says, "The Rip-Tie CableWrap is a reusable "hook and loop" fastener that keeps cables neatly and safely out of your way. One end permanently attaches to the cable; the other end has a pull tab to free it with one hand."
There are also other brands and variations. Search "cable tie" or "velcro tie" or other variations at B&H.
Old December 21st, 2007, 10:14 PM   #4
I stumbled onto the crossing the bands thing after my original post. What adifference! I thought I had come up with a workatound but it seems this is the proper way anyhow. Great AT equipment but lacking in any instructions. This is the first time I am running the sound myself so I have never dealt with them.
thanks.
So any tips or links to good techniques? Ian recording straight into my xlh1... I know it's not ideal but initial tests sound great. I will get some better gear on the next gig.
Thanks again.
Marty
Old December 22nd, 2007, 12:22 AM   #5
Thanks again.
Marty
The shockmount and mic you have are both excellent. They can give you professional results.
How are you operating the boom and the camera at the same time by yourself?
Old December 22nd, 2007, 08:03 AM   #6
I can't do both???
Seriously though, I have someone to operate the boom. He is not a sound guy professionally but he is a singer/ musician who has years of experience so I am hoping it turns out ok. Like before, any advice to help me avoid common pitfalls would be grand.
Old December 22nd, 2007, 08:34 AM   #7
ISeriously though, I have someone to operate the boom. He is not a sound guy professionally but he is a singer/ musician who has years of experience so I am hoping it turns out ok. Like before, any advice to help me avoid common pitfalls would be grand.
The best advice I can give is to buy a copy of Dean Miles book "Location Sound Simplified" http://www.locationaudiosimplified.com/
Dean goes through pretty much all the basics of booming in his book (also has loads of information on setting up mixers, wiring talent, and other essentials needed doing on-location sound).
Pretty much all the basics are covered and more in this book. I could give you tips, but this is the book I end up recommending to people who ask me about booming because I think Dean has nailed it.
Wayne
Mics: KMR 82 i, NTG-1, MKH418S, MKH8040, SR77, QTC1, QTC40, SR30
Recorder: Zaxcom Deva 5.8 & MIX-12. Wireless: TRX900 stereo, Lectro 411
Wayne Brissette is offline   Reply
