RCA to TRS or XLR? at DVinfo.net
All Things Audio
Old January 12th, 2008, 02:18 PM   #1
RCA to TRS or XLR?
I need to connect RCA outputs to some M-Audio monitors that accept either XLR or TRS 1/4". I see cables at B&H for both configurations. Is one preferred? Thanks for any help.
Rob Collins is offline   Reply With Quote
Old January 12th, 2008, 02:30 PM   #2
Nah, get what you want. XLRs are considered 'more professional' and have a locking mechanism but a TRS (1/4"?) is electrically the same.
Buy the cheapest, best made cable. I'd buy a good looking 1/4" cable than a cheezy XLR.
Andy Tejral
Railroad Videographer
Andy Tejral is offline   Reply With Quote
Old January 12th, 2008, 03:29 PM   #3
On the M-Audio speakers I see...
http://www.bhphotovideo.com/c/produc...Reference.html
... speakers that have XLR and 1/4" inputs, the XLR is for a balanced input, and the 1/4" can be balanced TRS or unbalances TS.
Since your are coming from an unbalanced RCA connection, the correct connection to the speakers would be the unbalanced 1/4" TS plug.
You can use this adapter on a regular RCA cable:
http://www.bhphotovideo.com/c/produc...apter_RCA.html
(you don't need the expensive Monster version)
You can get these at a local electronics store or even Radio Shack. It should cost around $3-$7. They might even come in a package as a pair.
Or you could use a cable with two 1/4" plugs and this adapter:
http://www.bhphotovideo.com/c/produc...ne_Female.html
(Note, it is possible to connect an unbalanced line to a balanced XLR connector if it is wired properly [they can be purchased], but in this case the RCA to the 1/4" TS plug is the best option.)
Last edited by Jack Walker; January 12th, 2008 at 04:45 PM. Reason: Add links to cable/adapter
Old January 13th, 2008, 08:24 AM   #4
Thanks very much for the information Jack and Andy.
