Stage mic question at DVinfo.net
All Things Audio
Old July 6th, 2008, 12:32 PM   #1
Stage mic question
Can anyone recommend a good mic for picking up stage show audio?. The feed from the sound board works for music, but I need to mix in some ambiance like tap shoes and other onstage sound as well as applause. I have a Sennheiser E604 mic I use for weddings, would this mic work? or should I look at something else?
Thanks in advance!
Ben
Ben Moore is offline   Reply With Quote
Old July 6th, 2008, 12:59 PM   #2
Mic for FX
I assume you refer to the sound board as an audio mixing console or desk. I use 2 Behringer C2 - 2 Matched Studio Condenser Microphones to pickup live soundeffects. These two mics are great for many purposes. Patch it to the audio desk and send it as a group to the audio recorder and the musictracks as another group. You can then mix it later in post.
Stephan de Lange is offline   Reply With Quote
Old July 15th, 2008, 11:32 AM   #3
Thanks Stephan for the advice, I will check into that.
Anyone use the Audio-Technica AT822 for stage micing?, seems to get good reviews.
Old July 15th, 2008, 12:13 PM   #4
Any and all of the mics that have been listed will work. I've used the C2 a number of times, though I've found it somewhat tinny and transparent. I really like the AT2020 (maybe 2021, can't remember right off hand). It's another small diaphragm condensor that sounds a little better than the C2. If you really want some good rich audio, you need to be looking at either a large diaphragm condenser or a really good small diaphragm condenser such as the Neumann KM184 or 185.
David Beisner
Media Specialist, Bryan College, Dayton, TN -- www.bryan.edu
David Beisner is offline   Reply With Quote
Old July 15th, 2008, 12:27 PM   #5
Floor mics (PZM/Boundary) are usually employed for this as they are low profile and unobtrusive. Crown PZM's are used in most professional productions, but I have had decent results with the low cost Nady CBM-40 (3 across the front of the stage):
http://www.nady.com/cbm40_mics_pg.html
Hanging area mics are the other approach to pickup the chorus/ensemble if they are not mic'd. Audio Technica has several to choose from:
http://www.sweetwater.com/store/sear...?s=hanging+mic
/BILLW
Bill Warshaw is offline   Reply With Quote
Old July 15th, 2008, 04:43 PM   #6
Fred Retread
You didn't say, but I guess we're assuming you have access to the stage or the pit area. Mic placement is the key issue. A $60 Sony mic up front will sound better than a $1600 Schoeps or Neumann at the back of the auditorium.
If you're forced to place the mic at the back, then a Rode Videomic is in the similar price range of your Senn, but will do a much better job than the Senn on those taps. The Rode is a shotgun, a pattern which you don't normally want to use indoors, but will be pretty good for the purpose of non-voice, non-musical stage sounds and the applause between your camera position and the stage.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old July 15th, 2008, 06:23 PM   #7
Crown pcc 160 on front of stage. Ideally 2 spread across for stereo.
Jimmy Tuffrey is offline   Reply
