Wireless Mic, sennheiser ew122p? at DVinfo.net
All Things Audio
Old August 4th, 2008, 08:49 AM   #1
I was recommended the EW122p for wedding use. Anyone tried this before? I can't find it on Senny website. Is it obselete? I'm not sure if it works well but it was written it is an export set.
Old August 4th, 2008, 09:39 AM   #2
The "G2" range is the current version. See here: http://www.sennheiser.co.uk/uk/icm.nsf/root/21411
Make sure:
(a) you get the correct version for your country (different - legal - frequencies) - check here and
(b) you investigate if you need the 500G2 series instead (as opposed to the 100G2 series you mention). A few more features, like phantom powering for mikes, headphone outputs from the receivers, more preset frequencies, etc. but not available in kits like the ew122pG2, you have to buy the (more expensive) components you need separately. Compare them here.
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old August 4th, 2008, 03:38 PM   #3
I studied the wireless systems recommended on here for a while before making a decision. I tried the Sennheiser G2 kit from B&H (about $500ish I think) for a wedding. It's really a fairly nice kit for the money. However, the the ME-2 (I think) mic that comes with it sounded poor and the signal transmission system seemed to have a softening, almost limiter like effect to it. I immediately sent it back.
I got a Lectrosonics 100 series next and highly reccomend it over the Sennheiser kit based on the sound quality. It's more of a tool where the Sennheiser had a bit of a consumer feel to it.
You could probably put another mic on the G2 kit and brighten/liven up the sound, but I would bite the bullet now and spend the money on a Lectrosonics.
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c
Jeff Kellam is offline   Reply With Quote
Old August 4th, 2008, 10:01 PM   #4
Thks for the inputs. We do not seem to have Lectrosonics here! As for the senny, my country isnt even on the list!
Old August 4th, 2008, 10:55 PM   #5
Dude, Lectrosonics is distributed by Hung Bros.
Hsien Yong is offline   Reply With Quote
Old August 5th, 2008, 10:38 AM   #6
Ah thanks! Wow the price is almost doubled. I would certainly expect better quality for that price.
Old August 5th, 2008, 06:25 PM   #7
Yah. I think the Sennheiser's are more value for money...
Lectros are not cheap.
Old August 5th, 2008, 07:18 PM   #8
Also if you felt that the sound was limited check the level settings on the trans and receiver they are really good and way better than any pro micron I have ever used.
Old August 5th, 2008, 08:17 PM   #9
Originally Posted by Gary Nattrass View Post
...way better than any pro micron I have ever used.
What was that about Microns...?
Jimmy Tuffrey is offline   Reply With Quote
Old August 5th, 2008, 09:20 PM   #10
Gary, I assume you are talking about the lectrosonics 100 being more superior?
Old August 6th, 2008, 03:39 AM   #11
I have used Microns for most of my TV career and they are very pro radio mics but all they have for adjusting levels is a single pot which changes the threshold of the in built limiter.
The sennheiser 112 radio mics I have have a superb menu system that allows you to change lots of things including accurate levels which can be checked on the meter, all the microns had was two leds.
I am not saying the microns are inferior as they are much more £££ than the sennys but the 112's have a great set up system.
Hope this clarifies that I was talking about the sennheiser operational set-up.
Gary Nattrass is offline   Reply
