-   -   Does this Right Angled XLR cable rotate? (https://www.dvinfo.net/forum/all-things-audio/141200-does-right-angled-xlr-cable-rotate.html)
Randy Panado January 9th, 2009 03:48 AM
Remote Audio | 3-Pin XLR Angled Male to XLR | REM CAXJ12RTMF
I'm looking at the male end, does it rotate so the cable goes upward? It seems from the picture that if it doesn't rotate, the end will point towards my cameras strap (XH-A1).
Can anyone confirm if it rotates?
Also, is there a difference in this cable :
Audio-Technica | XLR Male to XLR Angled Female | ASP00127 | B&H
and the first cable I posted? For the double right angled cable, it's a "jumper" cable. Just want to know if it's okay to use to connect my shotgun mic to my camera.
Andrew Dean January 9th, 2009 04:58 AM
This isnt definitive by any means, but i bought a similar looking short right angle lead for a similar purpose. The right angle does not "rotate", but i was able to unscrew the connector on the end and had the option of (gently) repositioning the "xlr" part to lock into place in four positions (up, down, left or right).
I could be wrong, but i believe all these 90 degree connectors are designed the same way. Unscrew the connector, carefully reposition how you want it (without stressing the cables), then screw it back together. It makes more sense than having to sell specific connectors for the angle you want the connector.
So, i believe either of those cables would work for you. Big difference i saw between the two is one was right angle on one end, other was right angle on both. Electronically and acoustically, there is zero difference between those two cable options. Its just a matter of which connector you prefer.
cheers!
Randy Panado January 9th, 2009 05:18 AM
Thanks Andrew! I appreciate you sharing your insight and experience.
I just found through searching a link to oktava and saw they made custom cables. I shot them an email to see what they could do for me. It should come out cheaper than the above cables.
Have a good one :).
Steve House January 9th, 2009 07:02 AM
Just FYI - some right-angle XLR connectors can be assembled with your choice of orientation, others only go together one way. Which is used on various manufacturers commercially assembled cables would be anyone's guess. The best way to find out would be to contact the manufacturer directly. Between those two cables you posted, Remote Audio would probably be more accessible than A/T, simply because Remote is a small company catering pretty much to the professional market (it's actually a division of Trew Audio).
Rick Reineke January 9th, 2009 11:45 AM
Neutrik RX series can be set in 5 fixed positions. (around 360 degrees)
Neutrik - Audio - RX Series - NC3MRX-BAG
John Willett January 10th, 2009 07:35 AM
The picture linked to looks like a Neutrik.
In which case it should be able to be repositioned.
Maurice Ali January 10th, 2009 08:41 AM
Yes they can be rotated but it can get "stiff" depending on the amount of rotation - male and female. You have to disassemble the connector to do this, pretty simple stuff (Neutrik). I had some cables custom made and had to rotate them to fit the application. It works, see the photo below.
http://fortressoffreedom.com/Office231.jpg
