-   -   New minidisc format. VERY interesting (https://www.dvinfo.net/forum/all-things-audio/19469-new-minidisc-format-very-interesting.html)
Marco Leavitt September 3rd, 2004 06:19 AM
Have you tried this? The post is from the forums at www.minidisc.org. It details how to use a program called Total Recorder to capture digitally from the minidisc as a WAV file.
http://forums.minidisc.org/viewtopic.php?t=5858&sid=13523f2c6b8b3d8d134c4e0119317f1b
Will Fastie September 5th, 2004 08:56 AM
I saw the post at MiniDisc.org. The only problem I have with the technique is that its transfer rate is 1-to-1, real time. The advantage of digital over USB should be speed, enough so that most tracks would transfer from the disc to the PC in a matter of seconds.
Total Recorder at least captures the digital format, even if it is 1-to-1. That's an improvement over what I do now, which is recording the analog signal from the MiniDisc on line in, also 1-to-1.
I haven't tried the technique because I won't buy Hi-MD until I'm sure I can get the functionality I want. I'd certainly be happy to pay another $12 to overcome this silly SonicStage limitation.
Will
