Can VX2000 record 48khz? at DVinfo.net
All Things Audio
Old February 4th, 2004, 08:58 PM   #1
Hi all,
Does anyone know if VX2000 can record at 48khz. I know that it is capable of either 12 bit or 16 bit, but I can't seem to find any info on khz.
Thank's in advance.
Bob
Bob Schneider is offline   Reply With Quote
Old February 4th, 2004, 09:05 PM   #2
The audio recording formats should be in the manual,
on the specifications page.
The VX2000 supports particular audio combinations that
are part of the DV specification. The miniDV format
allows for 48000 Hz/16-bit two channel recording
and 32000 Hz/12-bit four channel recording. The
VX2000 supports both recording formats
, but doesn't provide the connections for four
channel recording. This can be done with its overdubbing
function.
Gints Klimanis is offline   Reply With Quote
Old February 4th, 2004, 09:11 PM   #3
48 khz
Thanks Gints,
I just read the spec page. You are right. I guess 16 bit in the mini DV format automatically indicates 48khz. So much to learn.
Bob
