Microphone mounting to GL-2 at DVinfo.net
All Things Audio
Old March 23rd, 2004, 05:32 PM   #1
I am using an AT897 short shotgun microphone and an AT8415 shock mount - which I use with a microphone boom. But I'd like to connect the shockmount directly to the shoe that's on top of the MA-300 audio adapter on my GL-2.
Is there an adapter that will slide into the shoe mount with a threaded bolt facing upward so I could screw the 8415 shock mount onto it?
The shoe on the MA-300 has no electrical connections. It's just a physical mount point so it would be perfect if I can find the right adapter...
By the way, I know there is a microphone clamp on the MA-300 already but it doesn't work with mics that are as small in diameter as the 897 and anyway it doesn't provide as much isolation from the camera.
Bob Reed
Bob Reed is offline   Reply With Quote
Old March 23rd, 2004, 08:48 PM   #2
http://www.bhphotovideo.com/bnh/cont...u=68160&is=REG
dB
Dan Brown is offline   Reply With Quote
Old March 25th, 2004, 09:35 PM   #3
Thanks Dan. Just what the doctor ordered!
