TA5F to 1/8" Mini Adapter? at DVinfo.net
All Things Audio
Old May 21st, 2009, 12:29 AM   #1
I was wondering if there is an adapter to go from TA5F to 1/8" mini.
Pretty much what I'd like to do is plug my Tram TR50 which is wired for Lectrosonics, and plug the mic into a MiniDisc recorder.
As of now, I know I could go from TR50 into TR79, use a XLR to 1/4" cable, and then a 1/4" to 1/8" adapter. But that seems really bulky, and was looking to see if anyone knew of a simpler way w/o cutting up my mic cable.
Zach Love is offline   Reply With Quote
Old May 21st, 2009, 11:29 AM   #2
You will need to get power to the Tram somehow if you don't use the TR79.
Is the 1/8" jack powered?
The MicroTrack apparently can power a mic through the 1/8" jack. Here is a VoiceTechnologies mic wired for this:
microtrack | B&H Photo Video
But I haven't seen a Tram wired this way, and I haven't seen an adapter -- though I would like one as I have a TR50 I would like to use with the 1/8" input and not use the power supply and bulky XLR cable.
Old May 21st, 2009, 03:34 PM   #3
I know that 1/8" mic jacks can provide some power, although I don't know if it would be enough.
Maybe this would work to test it out:
Remote Audio | TA5-Male Connector | TA5M-B | B&H Photo Video
And see if I can wire this to a 1/8" jack.
Anyone know what the chances I could blow out my TR50?
Old May 23rd, 2009, 05:49 PM   #4
The little Sony PCM D50 recorder can also put around 5V on the 1/8 mic port.
Jim Andrada is offline   Reply
