Lav mic and a shotgun at DVinfo.net
All Things Audio
Old July 12th, 2004, 01:39 PM   #1
Well, I had posted a question earlier about skimping a little in quatlity for a lav mic and a shotgun, but now I think I'm going to get both at good quality. I'm going to get an AT835b shotgun and a lav microphone. My main question is, can I plug one in one channel and one on the other channel of the GL2?
With the extra expense of purchasing both mics, I really would like to wait on an XLR dual adapter.
So has anyone tried this, plugging a lav in one audio input and a shotgun in the other audio input?
Any feedback would greatly be appreciated.
Old January 3rd, 2005, 09:22 PM   #2
I was wondering this myself. Your lav is a wireless right?
It should be fine, as you will be recording to two channels and can separate it in post if you need to (hopefully you are find with mxing both into mono...who knows. Can I seperate each channel within Adobe Premiere 6.5?).
But I did wonder about weird hums or echos or what not....
Ronald Lee is offline   Reply With Quote
Old January 3rd, 2005, 10:07 PM   #3
Yeah I'm good to go, the purchase went well, but I will end up getting a better wireless, mine uses the wire for the antenna, and I've gotten some interferance. BUt thanks for the reply.
Old January 3rd, 2005, 11:11 PM   #4
Re: Lav mic and a shotgun
<<<-- Originally posted by Steven Davis : <snip>
</snip> -->>>
So Steven, how are you going to connect the mics to the GL2 since the GL2 has only one external mic input which is a stereo 1/8-in minijack and the AT835B has a XLR connector?
I have found the BeachTek DXA-4P audio adapter to work quite well with the GL2. Around $150 new but you can get them used on eBay much cheaper.
Pete Wilie is offline   Reply With Quote
Old January 3rd, 2005, 11:55 PM   #5
I wouild strongly suggest the use of an XLR to 1/8" stereo adapter like the Beachteck or Sign Video two channel on-camera mixers. These devices are engineered to provide the best audio signal transfer to your GL2. You will have much more control of signal quality. Besides, finding a dual XLR-F to 1/8" - M stereo cable adapter that is reliably made will not be an easy task. You may spend more than $150 of your time just locating a supplier!
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old January 4th, 2005, 12:39 AM   #6
There is a 1 ft and a 5 ft cable available, made by Hosatech. I own one and they work. Mine is a 1/8 angled stereo to two female XLR's. The right and left channels are separated. Talk to the salesman at B&H and confirm that this is the correct number. There has been mistakes in the past. (There are so many different cables)
Hosa Tech Cable
Are the left and right channels on your camera individually controlled. ifd not, yopu may have to play around with inline attenuators, in which case a beach would be a wise choice.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting ".......holy smokin rubber lips...what a ride!"
Bryan Beasleigh is offline   Reply
